ᐅ Roof Insulation for New Hip Roof Construction to Meet KfW 40 Standard
Created on: 8 Oct 2021 14:07
Dany250
Hello dear community,
we are currently planning our new KfW40+ single-family house with a prefabricated house provider. Although the contract is not yet signed, we are about 98.9% sure that this will be the one. The offer somewhat reveals the manufacturer’s construction method, which leads to my question.
I have absolutely no knowledge of house construction or anything similar, so here is the consideration of a complete layperson. The offer states the following:
For an attic that is not intended for expansion, a nail plate roof truss structure is built in traditional craft-style according to static calculations. The attic space is not accessible with this roof structure.
Construction from inside to outside:
21 x 76 mm and 30 x 80 mm substructure
200.0 mm (8 inches) thermal insulation at ceiling level
solid nailed truss according to calculation
roof underlay membrane
counter battens 40 x 60 mm (1.5 x 2.5 inches)
roof battens 40 x 60 mm (1.5 x 2.5 inches) or 40 x 80 mm (1.5 x 3 inches)
Increase of rafters and insulation: 200 mm to 280 mm (8 to 11 inches) → U-value = 0.14
(for nailed plate roof bottom chord and insulation)
Does this mean that the “standard roof” insulation thickness is being changed from 200 mm to 280 mm?
Can you estimate if this is a reasonable and good level of insulation? Or could you go even further? What confuses me is that the insulation is not applied on the roof itself, but rather only in the uppermost floor ceiling. Does this mean that the roof is not insulated at all?
As someone who grew up in an attic, I am quite sensitive to this. It’s less about the thermal insulation for me and more about summer heat protection. I am approaching my forties and have always slept directly under the roof throughout my life. For the rest of my life, I would simply want to avoid spending summers “cooked” in my own heat.
Our bedroom is upstairs, and I am hoping that with KfW40, underfloor cooling, and of course good shading, my sleep quality will improve significantly in summer.
I am also a bit worried about the:
which is recessed into the attic when not in use
Isn’t this also a “gap” allowing heat to pass through?
I would greatly appreciate constructive feedback. Maybe my concerns are completely unfounded and everything is fine. I just don’t want to save in the wrong place when it comes to the biggest investment of my life.
Thank you very much and best regards
Dany
- Nail plate roof truss, roof pitch => 23°
- Increase of rafters and bottom chords in nailed plate roofs from 200 mm to 280 mm
- ceiling retractable staircase as a space-saving folding ladder,
Dany
Oh, so it is air-permeable? I thought it would heat up and the warmth wouldn’t be able to escape (vented out)... That means my concern about the roof not cooling down enough at night is unfounded, right?
I assumed it would heat up and eventually the heat would naturally transfer downwards. But if it actually releases the heat at night, that sounds good. Thanks for that too! Also for the statement that the only real improvement would be thicker insulation in the upper floor ceiling.
Can anyone say something about the door to the upper floor? Wouldn’t that be a bottleneck then?
Dany250 schrieb:
I’m very curious to see your fresh response.Now it’s your turn; your homework is in post #3. The options for abstract explanations are limited.https://www.instagram.com/11antgmxde/
