ᐅ Roof Connection of Patio Roof to Stone Wall
Created on: 4 May 2023 10:58
arichter
arichter
4 May 2023 10:58
Hello everyone!
I have an acrylic glass patio roof with an aluminum wall connection profile. The previous owner sealed it improperly against the stone wall using expanding foam, which the sun has broken down over the years, causing leaks. I’m now considering how to do this better.
Concrete the wall with formwork to get a straight connection? -> you’ll never get it off again
Seal it with bitumen? -> the offsets of up to 3cm (1.2 inches) are quite large for that
A tin profile or similar that I can easily nail on and then glue with bitumen adhesive? -> messy and makeshift, but maybe the only option?
Thanks for your tips!
Andreas
Tolentino4 May 2023 15:24
I’m not sure if this is technically correct, but maybe sealing it with a 3-layer multifunctional compression tape? Or alternatively, using foam again but then covering the foam with something UV-resistant...
