I am considering which option is better in terms of effort, time, and difficulty.
We are building a prefabricated house next year and will be doing the ceiling paneling and joint filling ourselves.
The question is how we should fill and finish the drywall boards:
- Smooth joint filling (level 3 finish), with several work steps, followed by a textured roller plaster?
or
- A rough joint fill once, then a standard plaster finish?
Has anyone tried both methods and can compare them?
Is it feasible for a layperson to achieve a level 3 finish with reasonable effort?
Thank you very much and best regards
KingJulien
or
KingJulien
Okay, understood. I only mentioned Q3 because I read that this level is needed for fine textured plaster.
To put it another way: As a non-professional, is it even possible to apply the skim coat well enough to achieve a reasonably good result with textured plaster? With a reasonable amount of effort?
Or is it better to apply a regular plaster finish after a rough skim coat? Would the effort be significantly greater in that case?
Or simply put: What would you do if you had to choose?
