we were asked if we wanted to have rolling layers (roller screeds) at the patio doors. As far as I know, it’s definitely not a bad idea in terms of water protection. However, I’m not particularly keen on them because we specifically chose a low-profile construction for the patio door. We wanted to avoid a high step, but the rolling layer would create one again. You can find mixed opinions about this online, as is probably the case everywhere.
Has anyone here decided against the rolling layer and could share how they sealed the area later on? Are your patio slabs or paving installed directly up to the door, or is there a drainage channel in between?
So far, several coats of MB 2k from Remmers have been applied.
I would appreciate any tips.
nordanney3 Jul 2019 14:47Wooden deck up to the door (without a gravel layer). This way, you also avoid having an unsightly grate in front of it.
hemali20033 Jul 2019 14:47danixf schrieb:
Did you have the patio slabs or paving right up to the door, or is there a drainage channel in between?My husband insisted on having a channel. However, our research showed that hardly anyone does this, so we decided against it. Due to the slope and the roof overhang, even heavy rainwater doesn’t really reach that area, so a channel wasn’t necessary!
If we had solidly grouted tiles, I probably would have opted for it, but in our case it didn’t make any sense. We realized this only afterward.
hemali20033 Jul 2019 14:48Oh, unless the door is completely flush with the floor, then we probably would have installed a trench drain!
hemali2003 schrieb:
Oh, unless the door is completely flush with the floor, then we would probably have installed a drain! That is the OP’s plan.
