ᐅ Sliding Systems for the KALLAX – Are Purchased or DIY Solutions More Suitable?
Created on: 15 Nov 2024 19:37
Belo61Hello everyone,
I am currently looking into the topic of caster assemblies for the KALLAX shelving system and have noticed that there are two common options: on one hand, the ready-made casters specifically designed for KALLAX, which can simply be attached or screwed on, and on the other hand, DIY solutions where you source suitable casters yourself and design your own mounting solution, which can be more or less complex.
I’m particularly interested in hearing about your experiences with both options. Are the specially offered KALLAX casters really better in terms of durability, stability, and assembly? Are there maybe advantages to DIY solutions that sometimes offer better load capacity or aesthetics?
And very importantly: how does the effort compare when mounting both the ready-made and DIY options?
I look forward to detailed opinions, including tips on what to pay special attention to when putting KALLAX on casters.
Best regards!
Best regards!
It’s great that you brought up this topic! 🙂 I’ve tried both the original KALLAX casters and DIY casters, and I can only say: The original casters are really easy to install and look great. Especially if you don’t have much time or DIY skills, buying the casters is a huge relief!
I would say yes, they hold up surprisingly well and don’t tip over even with heavy loads. If you want to move the KALLAX frequently, these casters are excellent—no catching or stiffness.
But I still think DIY is cool, especially if you use unique casters, like those with leather straps or wood, which really give your shelf character! You just have to put in a bit more effort… But hey, “Do it yourself!” 😉
Belo61 schrieb:
Are these specially offered KALLAX casters really better in terms of durability, stability, and assembly?
Good morning everyone,
to look at the topic from a more technical perspective: The KALLAX casters offered by IKEA are generally rated for a load capacity of about 15-20 kg (33-44 lbs) per caster, which means a maximum load capacity of around 60-80 kg (132-176 lbs) for a shelf with four casters. The mounting clips are tailored to the shelf and provide a secure hold without any play.
DIY solutions, on the other hand, sometimes offer higher load capacities due to the freedom of caster choice, especially when heavy-duty casters are used. However, the critical point here is the mounting on the KALLAX back panel or underside. The material thickness of the KALLAX panel is only about 1.5 cm (0.6 inches), so the attachment must be designed to prevent cracking or deformation.
That is true, and the advantage of simplicity should not be underestimated. However, if you are, for example, putting heavy loads on drawers or boxes and moving a lot of weight, DIY solutions with metal brackets and high-quality ball-bearing wheels can be sensible, provided you have the necessary craftsmanship.
I would like to know how heavy the shelf actually gets in use and what kind of floor coverings you have, since casters with soft PU tires are better for hard floors than plastic wheels.
If anyone wants, feel free to share your load profiles with me, and I can give more specific recommendations.
Davidleo schrieb:
The original casters are super easy to install... hold surprisingly well
I’ll keep it brief but want to add an important point that Filippo only briefly mentioned.
Sure, the IKEA casters are very suitable for standard use. However, when it comes to DIY solutions, you shouldn’t compromise on the attachment method. It is important to secure the casters with sufficiently wide metal plates or brackets to evenly distribute the pressure on the thin particleboard of the KALLAX, so as to avoid material failure.
I also recommend using casters with locks for DIY options. Especially if you have a KALLAX with multiple boxes or electronics on casters, the lock prevents unwanted slipping.
I agree. If you can pay the necessary attention to detail, you get more flexibility here, otherwise the original casters are usually the best choice.
Filippo schrieb:
DIY solutions can offer higher load capacities, provided you have the necessary craftsmanship skills.
To be honest, I often find the debate over whether buying or DIY is better to be too one-sided. Sure, many swear by the original casters because they fit perfectly and are simple to use. But at the same time, it often seems like IKEA is just delivering standardized products that offer little individuality and quality beyond the standard level.
Is that really the case? Some reviews mention poor plastic that wears out quickly.
I wonder if it’s better to invest in custom caster systems with metal axles, rubber wheels, and more advanced features that turn the small KALLAX into a true rolling monster. Of course, that’s more complex and expensive, but why not leave the standard system behind and create something really sturdy?
For me, DIY is not just a last resort, but actually an opportunity to take this ironically ingenious IKEA shelf to a new level.
The question is: Has anyone here already installed such “premium DIY casters” on a KALLAX? And how practical are they for everyday use?
Davidleo schrieb:
If you want to move the KALLAX often, the casters are great – no jamming or stiffness.
