ᐅ Retrofitting and Properly Adjusting Soft-Close Mechanisms on IKEA Metod Doors
Created on: 30 Mar 2023 09:17
Laarbenor
Hello everyone, I already have several IKEA Metod kitchen cabinets at home without soft-close functionality on the doors. Now I want to retrofit these doors with soft-close dampers and properly adjust them later, so they not only close gently but also do not bounce back or catch. Since IKEA does not offer soft-close doors as a standard option for Metod, I’m looking for advice on the following topics: - Which retrofit solutions are of good quality and compatible with Metod doors? - How can I professionally attach the soft-close dampers without damaging the doors or the carcass? - What should I consider when adjusting them, especially regarding closing speed and the gentle final stop? - Personal experiences with this retrofit would be very helpful, particularly concerning durability and ease of use. I appreciate any tips or tricks!
Leote
31 Mar 2023 11:46
draleo schrieb:
When adjusting, pay attention to the resistance of the damping spring, which is often adjustable.
I can only agree with that. A small tip: If you notice that the door doesn’t close properly, reduce the damping a bit so it closes more easily. The damping is not a restriction, but an aid during closing.
ju_ren
1 Apr 2023 07:21
Just a quick note: Make sure that the door does not stick or become difficult to operate after installing the dampers. This often happens when the dampers are positioned incorrectly. Adjust as needed and check again, especially when closing.
Laarbenor
1 Apr 2023 09:57
BiDennis schrieb:
A tip: Before installing on an old part or a replacement panel, first temporarily fix the damper with painter’s tape and test if the closing action is smooth.
Thanks for the helpful tip, I will definitely try that to avoid unnecessary drilling.
I was also wondering if the position of the soft-close dampers varies for different door sizes in Metod. Do you need to choose different positions or larger dampers, or is the system largely the same for all doors?
Also: Is it possible that for larger doors additional door damping elements are needed at the bottom edge to prevent wobbling or uneven closing?
Looking forward to more advice!
