ᐅ Retrofitting Exposed Concrete – Is It Possible?
Created on: 19 Feb 2020 07:17
LostWolf
LostWolf
19 Feb 2020 07:17
I must also admit that I have fallen for the style of exposed concrete. Unfortunately, I do not have the opportunity to realize this in a new build, as I am renovating an old property (built in 1961). However, since a larger new wall is going to be erected, I am interested in whether there might be a way to incorporate such an exposed concrete wall. (Maybe there are methods I haven’t thought of or am not aware of yet, but that are still possible.)
The color-trowel solutions can look nice from a distance but are clearly recognizable as “fake” up close. I have considered thin cast panels that I could attach to the wall, but I am still unclear on how this could be implemented.
rick201819 Feb 2020 08:29
There are now filling systems that look very realistic even up close, using mineral plaster and texture foil.
I’m not sure if there is any panel material available. However, I see a structural issue and you would end up with unattractive joints.
I’ve seen a wall made with texture foil before. Even up close, you can’t tell whether it’s real or not.
If we didn’t have concrete walls, I would go for that.
mertmk3
19 Feb 2020 12:55
I have a fair-faced concrete ceiling on the ground floor that was repaired and treated due to defects, so it’s no longer true fair-faced concrete. However, the appearance is excellent, and there are companies that offer this kind of work.
Keywords you can look for are: concrete retouching, concrete cosmetics, béton ciré.
The manufacturer Carameo also offers putty systems, but you’ll have to judge their quality yourself. In our case, the fair-faced concrete ceiling was ground, partially repaired, and then uniformly treated with a tinted but transparent glaze to achieve a fair-faced concrete look. No putty was applied.
I like it.
Vicky Pedia19 Feb 2020 14:05
rick2018 schrieb:
There are now filler systems that look very realistic even up close, using mineral plaster and textured foil.
I’m not sure if panel materials exist. However, I see a structural issue, and you end up with unattractive joints.
I’ve seen a wall made with textured foil before. Even up close, you can’t tell if it’s real or not.
If we didn’t have concrete walls, I would consider using it.
You might want to get advice from a good specialist company. If it’s done well, it really can’t be noticed.
bortel
19 Feb 2020 14:06
Have a look at Volimea, their offerings look really good.
