ᐅ Adding Custom Handles to Kallax Doors – How to Drill?
Created on: 4 May 2024 09:37
russel64
russel64
4 May 2024 09:37
I am planning to retrofit my IKEA Kallax cabinet doors with custom handles since I don’t like the standard ones. The issue is that the doors are made from relatively thin material, and I’m unsure how to drill the holes for the handles without splitting or warping the material.
Also, which drill bit is best suited for this thin, particleboard wood, and what technique should I use (e.g., countersinking, drilling slowly, supporting from the back)?
Do you have any tips on what to watch out for, how to mark the drill points accurately, and what size screws and holes are ideal for standard furniture handles?
I want to achieve clean and sturdy results without damaging the doors. Looking forward to your experiences and recommendations!
Domau0
4 May 2024 11:12
Hello russel64,
First of all, it’s a great idea to install custom handles on Kallax doors; it can really enhance their look! Regarding your question:
When drilling into Kallax doors, which are indeed made from thin MDF with a melamine or foil coating, careful preparation and caution are key. I recommend the following steps:
1. Marking: Be sure to use a square and a ruler or a template to ensure the drill holes are precisely positioned. Even a slight offset or step will be noticeable.
2. Drill bit type: A sharp wood drill bit with a centering tip is ideal. Standard metal drill bits are too aggressive for MDF. You can also use so-called “spiral wood bits” (e.g., spade bits with a centering tip) that allow for a clean cut.
3. Support: Since the door material is thin and fragile, place a piece of wood or a sturdy mat behind it to minimize splintering when drilling through. This significantly reduces chipping.
4. Drill slowly: Set your drill to a moderate speed and apply gentle pressure. It’s better to proceed carefully with less force.
5. Countersinking: After drilling, you can use a small countersink to chamfer the holes; this helps the screws sit flush and the handles fit neatly.
6. Screw size: M4 screws are common for furniture handles, but this depends on the handle itself. It’s best to measure the screws provided or follow standard sizes. The hole should be drilled roughly the same size or slightly larger (e.g., 4.5 mm (0.18 inch) for M4 screws) to allow some play for adjustment.
One quick question: Do you already have a clear idea of the handle design and whether the handles will be mounted on the door from the inside or outside? This can affect the drilling positions.
If you want, I can prepare a simple sketch with typical measurements and spacing for you.
Good luck!
bauku
5 May 2024 14:44
Great explanations, thanks! 🙂
I recently upgraded my Kallax doors with new handles, and I can confirm: proper support at the back is absolutely essential! I simply placed two boards under the door while drilling, which really protected the surface.
One more tip: if you want, you can pre-score the drilling spot with a thin nail or an awl to prevent the drill from slipping. This helps make the holes even cleaner.
No need to stress! Just drill calmly and carefully—the doors are sturdy enough as long as you’re gentle.
The result looks really cool—I chose handles that slightly protrude, which makes opening easier and looks very stylish.
Have fun with your DIY project, it’s really a small victory once your own handles are installed!! :-)
Jensson
6 May 2024 08:21
Hello russel64,
to summarize the topic systematically and provide you with a small "mini-tutorial":
1. Preparation: Mark the exact drilling points with a pencil. Use a ruler or a sturdy template to ensure all doors are consistent. Use fine-grit for precise marking.
2. Center Punching: Slightly indent the drilling spot with a center punch or a sharp tool to prevent the drill bit from wandering on thin material.
3. Tools: A very sharp wood drill bit with the correct diameter (usually 4 mm to 5 mm (0.16 to 0.2 inches)) is ideal. The Kallax doors are sensitive to excessive stress; avoid metal drill bits to prevent cracking.
4. Speed and Drilling Technique: Set the drill to low to medium speed; drill slowly and apply moderate pressure. Place a backing support on the backside (e.g., scrap wood) to avoid splintering.
5. Countersinking: It is recommended to use a countersink or router to deburr the holes on the visible side and clean up the screw guides.
6. Screws: Most handles use screws with M4 threads. Choose the exact length so that the screws do not penetrate through the door panel but still provide secure fastening.
Finally, my tip: avoid drilling holes too close together, as the material may crack. Test first on a scrap piece to get a feel for the material.
If you have any further questions, just ask!
