ᐅ Retrofitting Soft-Close Door Hinges on BILLY Shelving – Is It Possible?
Created on: 23 Feb 2024 13:47
leartanHello everyone,
I have a BILLY shelf with a single cabinet door, and I’m considering whether it’s possible to retrofit a soft-close hinge. So far, the doors have no damping and close quite quickly and loudly, which is a bit unpleasant for such a simple piece of furniture.
My specific question is: Does retrofitting soft-close hinges on a BILLY shelf work smoothly, or are there design constraints that need to be considered? Are there particular models or adapters you would recommend? Or is it more a case where you should expect some minor limitations or additional work?
I look forward to any experiences, tips, or warnings about potential pitfalls. Thanks in advance!
leartan schrieb:
Is it straightforward to retrofit soft-close hinges on a BILLY bookshelf, or are there design challenges to be aware of?Hello leartan,
in principle, retrofitting soft-close hinges on BILLY bookshelves is possible, but it can be a bit fiddly. The standard BILLY hinges are simple, so you need to replace them entirely with new hinges. You should pay attention to the mounting holes because the hole positions of soft-close models don’t always exactly match the existing ones.
leartan schrieb:
Are there specific models or adapters you would recommend?Many people use soft-close hinges from Blum, which are high quality and reliable. Installing them may require drilling new holes to properly align the hinges. Some also mention adding small wood reinforcements around the door area to optimize load-bearing.
It’s definitely worth spending some time on this because the result is much quieter and protects the wood. If done correctly, it works very well. I’m happy to send you a brief guide or some tips.
Good luck!
TRADI schrieb:
The standard Billy hinges are basic, so you have to completely replace them with new hinges.I would slightly disagree here. There are indeed solutions that act as an add-on mechanism, meaning sometimes a soft-close attachment that clips onto the existing hinges is enough. However, this is not the case for all models and doors of BILLY.
Therefore, the statement that you must fully unscrew and drill new holes should be differentiated. It really depends on the exact construction. Simply buying new hinges blindly and replacing them can end up being more expensive and time-consuming than expected.
leartan schrieb:
Or is it more a case where you have to expect minor limitations or extra effort?Yes, some effort is to be expected. I would recommend checking the exact measurements and the type of doors, then specifically looking for soft-close systems that are truly compatible. If necessary, a complete replacement remains the only option, but doing some research will save you time and money.
To clarify the technical situation, here is a brief overview:
The BILLY shelf system typically uses standard screw-on hinges with a 35 mm (1.4 inch) bore, designed for simple doors. Soft-close fittings from manufacturers like Blum or Hettich usually have a similar diameter but require precise drilling for the damper mechanism.
Since space on the inside of the doors of BILLY shelves is limited, mechanical adapters for retrofitting can be critical in terms of installation space.
Here are some detailed notes:
1. Completely replacing the hinges with soft-close systems is usually the cleanest solution.
2. There are retrofit kits that attach onto the existing hinges. However, these are often only compatible with specific hinge models.
3. Retrofitting usually requires at least pilot holes to fit the dampers perfectly.
Conclusion: Retrofitting is possible, but you should compare technical drawings of the hinges and drilling data. Precise planning helps avoid unnecessary damage.
kasan schrieb:
There are definitely solutions that function only as an add-on mechanism; in other words, sometimes a soft-close attachment that clips onto the existing hinges is sufficient.That was an interesting point for me – I mainly had a full solution with new hinges in mind and not so much the attachment options.
Are there any experiences here regarding how reliable such attachment systems actually are? Do they really last a long time, or is the wear significantly higher compared to fully integrated soft-close hinge systems?
Paxton38 schrieb:
Precise planning prevents unnecessary damage.I agree with that, which is why I want to be well prepared. Thanks for the technical advice; it helps me a lot with my further selection.
I will probably look at several products and then check whether I can retrofit them without having to completely ignore existing drill holes. If anyone has tips on specific product names or sources, please share 🙂
