ᐅ Retrofitting Lighting for a Billy Shelf – Wiring and Mounting
Created on: 2 Dec 2022 09:17
Youssefga
I want to retrofit my Billy shelf with lighting and have two main questions: First, which type of cable is best suited for power supply, especially if the goal is to keep it as discreet as possible – should I use thin stranded wires or something more robust? Second, I’m interested in how you most elegantly attach the light strips or lamps to the shelf without damaging the surface, while ensuring neat cable management.
I’ve already considered LED light strips, but I’m unsure about the best way to route the cables as unobtrusively and securely as possible, avoiding cable damage or a flimsy installation. Additionally, there’s the question of how to mechanically fix everything, since I want to alter the shelf as little as possible.
Looking forward to your experiences and tips!
Guyju
3 Dec 2022 08:09
Here is a simple step-by-step guide for retrofitting lighting to the Billy shelf to ensure a safe and neat result:
1. Planning:
- Measure: Where exactly should the lighting be installed?
- Check the power outlet: How close is the socket?
2. Cable selection:
- Use 2-core flexible wires, 0.75 mm², thin for concealed installation.
3. Mounting the light strips:
- Self-adhesive LED aluminum channels are convenient.
- Alternatively, use small screws and mounting clips that are barely visible.
4. Cable routing:
- Attach cable ducts or clips along the back panel or inside the shelf sides.
- Always route cables with sufficient bending radius, avoid sharp bends!
5. Installation:
- Connect the cables to the power adapter or transformer (pay attention to polarity).
- Attach the light strips by sticking or screwing them in place.
6. Testing & adjustment:
- Test the lighting.
- Secure cables again if necessary.
Tip: For cable routing at the shelf edge, drill small holes (3–4 mm (0.12–0.16 inches)) if cables cannot be routed otherwise. This keeps the appearance clean.
giabau
3 Dec 2022 15:56
As a supplement for cable routing and fastening:
Retrofitting lighting on the Billy shelf works best when following these steps:
- Use flexible stranded wires, preferably with silicone insulation, which are especially bendable.
- Aluminum profiles with clips that can be screwed in are suitable for mounting LED strips. This holds much better than tape, especially if the shelf is frequently moved or cleaned.
- For cable routing, self-adhesive cable ducts that can also be fixed with screws are recommended. This allows cables to be safely and neatly concealed.
- Make sure that cable connections are properly soldered or secured with connectors to avoid loose contacts.
These methods result in a durable and visually appealing finish.
raulso
4 Dec 2022 09:13
Nice discussion so far! 🙂
theota schrieb:
Why is tape always seen as a cure-all?
That’s exactly my view – I agree. For simple LED strips, tape is fine, but for heavier use or somewhat heavier fixtures, it’s better to use more secure fastenings.
Regarding the cable, I would recommend choosing a slightly more flexible cable right from the start, so you don’t have to cut or loosen it later. It’s also worth securing the cable routing with clips or small clamps. This keeps everything tidy and safe, and reduces the risk of damage from constant pulling.
In short: Putting a little more effort into the fastening pays off in the long run! 😉
