ᐅ Retrofitting a Bathroom Ventilation System with Heat Recovery
Created on: 21 Sep 2016 08:06
Jochen104
Jochen10421 Sep 2016 08:06
We built our house last year without a ventilation system and are quite satisfied with that.
Only in the bathroom, due to my wife’s long showers, there is often a noticeably increased humidity level. This, in turn, requires frequent airing, which makes the bathroom too cold for my wife 🙄
We are now considering retrofitting a ventilation system in the bathroom. We would like to install it on one of the two exterior walls. Power supply is available in the attic directly above.
We understand that a core drill hole will be necessary. However, we would prefer to run the electrical wiring either inside the wall or along the outside of the wall up to the attic. The reason is that the interior plaster is finished and nicely painted. On the outside, only the base coat plaster has been applied so far. There, we could simply chase a groove and then fill it again with base coat plaster. I am aware that this will create a small thermal bridge.
Has anyone done or arranged something like this before?
Are there any experiences or recommendations for specific devices?
Is the electrical wiring as described above possible?
Thank you very much 🙂
RobsonMKK21 Sep 2016 09:44
Good morning Jochen,
this initially sounds like a standard retrofit of a ventilation system in an existing building.
There are quite a few manufacturers that offer such ventilation systems. The biggest challenge in your case is likely the switch.
tomtom7921 Sep 2016 10:59
The switch is also not a problem if there is power. For example, an eocean impulse switch with radio control or from peha, etc.
RobsonMKK21 Sep 2016 11:14
Okay, so far I haven’t needed to look into it.
Then everything should be easy to implement.
Legurit
21 Sep 2016 11:41
A more powerful bathroom exhaust fan would be better, wouldn’t it?
Jochen10421 Sep 2016 13:57
Thank you all for the feedback.
@BeHaElJa, why would an exhaust-only system be better?
