I am looking for an affordable retrofit solution for a video intercom system. Additionally, I would like to create a way to access the house without using keys. Ideally, it would be great if both functions could work together.
Unfortunately, when the house was built, we didn’t really consider this, so we only have a 4-wire doorbell cable at the front door, and it’s positioned quite low, which is not ideal for a video intercom.
Possibly, it would be feasible to run a LAN cable with PoE from the utility room to the other side of the front door without too much effort.
I have read quite a bit on the topic, but I’m still not very clear.
Fingerprint access would be my preferred option, but from what I understand, fingerprints on children under 10 years old are often poor or unreadable.
I don’t want mobile phone control to be the only access method since my child doesn’t have a phone yet.
Active transponders sometimes cause issues when kept in pockets or handbags, which I don’t like.
Passive transponders or wristbands would be my favored option for the child.
I don’t want a PIN code to be the only access method, as neighborhood children can be quite curious, especially when they’re out with my child.
At the side door to the garage, I’ve had a simple visor tech system with PIN code and transponder for a few years.
It works 99% of the time but occasionally fails, requiring me to open the lock manually with a small Allen key and then reset it by reinserting the batteries.
For the main door to the house, I find that too unreliable.
The most flexible solution I found is the Somfy door lock with an additional RFID reader and optional PIN. Ekey support seems to be included as well.
Another advantage is that manual key operation is still possible.
There are certainly much cheaper alternatives, but those come with significantly fewer features.
Now the question is to what extent the door lock can be connected to a video intercom system.
This concerns, on the one hand, a potentially installed fingerprint scanner (whether Ekey or another brand) and, on the other hand, whether unlocking commands from the indoor station can be sent to the Somfy door lock.
I haven’t even been able to find information on whether the Somfy video door intercom v500 iO can be linked to the door lock. The Somfy forum seems to have been discontinued and replaced by an FAQ some time ago.
Does anyone have experience with these Somfy products or at least an idea of what I should be looking out for?
Doorbird also requires cloud connectivity.
untergasse43 schrieb:
Doorbird also requires cloud connection.That may be true, but the converter should be independent. At least, that's how I understand it.
Nairil schrieb:
That may be, but the converter should be independent. At least that's how I understand it. And what do you do with the converter without the Doorbird device? The doorbell needs to be connected to the internet, otherwise it simply won’t work.
