ᐅ Installing a Flush-Mounted Mailbox Retrofitting into External Wall Insulation (EWI)
Created on: 28 Oct 2022 20:38
Chloe83
Chloe83
28 Oct 2022 20:38
Good evening,
Our house exterior is finished, and we would like to have a flush-mounted mailbox with an integrated video intercom installed.
The issue (or maybe not an issue) is that this installation has to be done retrospectively. This means cutting an opening into the facade, specifically the external thermal insulation composite system (ETICS / external wall insulation) to a depth of 10cm (4 inches). That would leave 6cm (2.4 inches) of insulation and 20cm (8 inches) of sand-lime brick behind it, concerning thermal bridging.
We understand this is usually done before plastering, but our construction manager was not very accessible in some matters.
Is this still feasible at this stage, or would you advise against it?
Thanks!
Carli20211 Apr 2023 20:40
Hello Chloe,
I am now experiencing exactly the same problem as you. How did you manage to solve it?
Chloe83
1 Apr 2023 21:10
Carli2021 schrieb:
Hello Chloe,
I have exactly the same issue as you. How did you manage to solve it?
We are installing a flush-mounted mailbox with a DoorBird video intercom in May. An electrician will handle the installation (he has installed our model several times before). He said it won’t be a problem. There will still be some insulation left.
X
xMisterDx
17 Apr 2023 00:07
Well, if the electrician says so, it must be true. He is a recognized expert in ETICS (External Thermal Insulation Composite Systems) and surely knows all the details to consider, like joint sealing tapes, etc. The metal mailbox is also an ideal thermal bridge.
schubert7917 Apr 2023 06:12
No problem. We have had it for 10 years with no issues at all. Installed cleanly and sealed with sealing tape.
