ᐅ Retrofitting Billy Regal Screws – Which Replacement Parts Are Durable?
Created on: 10 Apr 2015 09:14
Cemgu
Hello everyone, I want to replace the screws on my IKEA Billy bookshelf because some have become worn out or broken over the years. My specific question is: based on experience, which replacement screws or fittings are more durable than the original screws from the Billy bookshelf and also fit the existing holes and connection system? I am looking for a long-lasting solution that makes the shelf more secure, especially when it is filled higher and carries somewhat heavier loads. I have considered metal screws, stronger wood screws, and alternative fasteners like metal brackets, but I am unsure which replacement parts are the most effective and easiest to install. Thanks in advance for your advice!
Evapau
11 Apr 2015 10:31
I would not recommend metal brackets without screws. The adhesive strength is not sufficient, especially for shelves under load. It is better to secure them additionally with screws.
barda6
12 Apr 2015 07:54
Conclusion from my experience: Galvanized or stainless steel screws with a diameter of 4-5 mm (0.16-0.2 inches) fit the pre-drilled holes, with a length of 30-40 mm (1.2-1.6 inches) depending on the shelf thickness. For increased stability, be sure to attach metal brackets with screws at the corners. This ensures the shelf remains secure and stable over time.
LANELE
12 Apr 2015 08:22
Cemgu schrieb:
Which replacement screws [...] are generally more durable than the original screws from Billy Regal and also fit the drill holes and connection systems?
I have had good experiences with stainless steel screws sold at hardware stores as furniture or chipboard screws. They are easy to retrofit and really sturdy. It is important that the screws are not too long; otherwise, the chipboard material can split.
