ᐅ Retrofitting and Properly Adjusting Ikea Metod Soft-Close Door Hinges
Created on: 30 Oct 2022 19:47
Kylefar
Kylefar
30 Oct 2022 19:47
Hello everyone, I would like to retrofit soft-close door hinges on my Ikea Metod kitchen and adjust them properly because the doors currently slam or don’t close smoothly. Unfortunately, I haven’t found any instructions that clearly explain how to easily and reliably retrofit soft-close hinges on Ikea Metod doors.
I’m particularly interested in whether there are special hinges that can replace the existing ones, or if additional parts are needed to make the soft-close function work. It would also be helpful to know how to adjust them to align the doors precisely and fine-tune the soft-close function so the doors close quietly and gently.
Has anyone had experience retrofitting and fine-tuning these hinges? Tips on tools, important details, and step-by-step instructions would be very appreciated. Thanks in advance!
Marlenepa
30 Oct 2022 20:15
Hello Kylefar, I’m happy to help you!
You can actually retrofit the Ikea Metod soft-close door hinges without much effort. It’s important to buy the correct hinge designed for Metod kitchens, which is a 110° hinge system with integrated damping.
- You only need to replace the standard hinges with the soft-close version; there is no additional mechanism that needs to be installed separately.
- For retrofitting, you must remove the door, unscrew the old hinges, and attach the new ones in the same position.
- There are usually three adjustment screws: height adjustment on the cup, lateral adjustment on the mounting plate, and depth adjustment directly on the hinge.
- These allow you to precisely align the door in all directions.
- The soft-close function is pre-set at the factory, but if the doors don’t close properly, tightening or loosening the hinge slightly can help.
You will need a normal Phillips screwdriver or a cordless drill with the appropriate bit. It’s best to check the closing several times after installation and adjustment, and then fine-tune as needed. If the door sticks, adjust a few millimeters.
If you want more details on the adjustments or the exact procedure, I’m happy to help further. Good luck!
Siflo
31 Oct 2022 07:22
That is correct and important to add: the soft-close hinges for Metod are modular in design. The damping unit is already integrated within the hinge; there is no separate component that needs to be installed.
Three adjustment screws are relevant for proper alignment:
- Side adjustment: horizontal, adjusts the gap to the cabinet carcass.
- Height adjustment: via the metal plate on the cabinet side, aligns the door vertically.
- Depth adjustment: controls the distance between the door and the cabinet front.
All three screws should be adjusted gradually and in small increments to ensure optimal alignment and function. The closing action is controlled by the built-in damping and should be soft and quiet almost immediately after installation.
Note: There are different types of hinges for various opening angles (e.g., 110° hinge vs. 170°), so you should make sure the soft-close version matches the opening angle of your doors.
Summary of the main points:
- Remove old hinges and replace with soft-close hinges 1:1
- Pay attention to the three adjustment points
- Tool needed: Phillips screwdriver
- Fine-tune after initial testing
Retrofitting does not require special prior knowledge but does need some patience for proper adjustment.
karlau
1 Nov 2022 01:08
Kylefar schrieb:
I am mainly interested in whether there are special hinges that can be used instead of the existing ones, or if additional parts are needed for the soft-close function to work.
One could also argue that the demand for soft-close is a marketing product designed to make us believe that doors must close softly for our lives to improve. Why not just use conventional hinges that do their job without the technical gimmicks?
Still, if you want it, yes, there are definitely compatible soft-close hinges for Metod that can simply be used as replacements. Additional parts are actually not necessary, as the damper is integrated. So it’s not more complicated than it needs to be.
Marlenepa schrieb:
There are usually three adjustment screws: height adjustment on the cup, side adjustment on the mounting plate, and depth adjustment directly on the hinge.
That naturally raises the question of how much you should fiddle with them. In my experience, doors often shift again unless you treat them a bit more roughly. With overly fine adjustments, you can also drive yourself crazy — the perfect setting is a myth.
At least for those who try: impatience is the enemy. Keep your fingers off the adjustment screws while the door is still hanging. Fully assemble first, then make the adjustments; otherwise, it’s easy to get confused.
