ᐅ Replacing MALM drawer handles – what is the proper procedure?
Created on: 15 Jun 2021 08:17
Tanjon
Hello everyone, I want to replace the drawer handles on my Malm sideboard. I’m interested in hearing how you approach this.
Specifically: Do you need any special tools to unscrew the handles? Are the screws usually standard everywhere, or are there differences? And what about installing new handles, which sometimes can be a bit different from the manufacturer?
I definitely want to avoid drilling holes in the wrong place or damaging the surface. Are there any experiences or tips on the exact procedure to get everything done cleanly and without rework?
Looking forward to your feedback!
Hi Tanjon,
I recently did the same and found the following tip very helpful: When removing the handles, I placed a towel underneath – drawers are often smooth and can slip away easily.
Exactly that, but with a bit more fun! 😉
Also, if you buy new handles that are slightly larger, make sure the screw holes actually match. I had the problem that I didn’t want to drill new holes and then had to use spacers.
Good luck and don’t be afraid of the work! 🙂
Elijah42 schrieb:
Pull out the drawer, loosen the screws from the inside.
Tanjon schrieb:
Are there any experiences or perhaps tips on the exact procedure to complete everything as neatly as possible and without rework?To avoid rework, the following procedure is recommended:
1. Measure the thread length and hole spacing of the handles
2. Test the new handles on the countertop surface; if necessary, verify the hole spacing on the drawer using precise measuring methods
3. Use a soft cloth or protective strip under the handle during installation to prevent surface scratches
4. Tighten the screws carefully and steadily
Generally, drilling additional handle holes on Malm furniture is uncommon, as the piece is precisely pre-drilled during manufacturing. If there are deviations with newer handles, be sure to clarify before installation whether adjustments are possible or if special accessories are required.
A skilled, methodical approach also means minimizing effort and potential sources of error.
