ᐅ Replacing KALLAX hinges after they have torn out – how do you usually proceed?
Created on: 7 Nov 2022 10:23
TasauHello everyone, I have a KALLAX shelf where several hinges have torn out, especially on the doors I use regularly. My question is: How do you handle it when the hinges have pulled out of the wood? Do you just replace the hinges and screw them back into the original spots, or do you use special repair kits or other techniques to make the attachment stable again? Should the holes be filled with wood filler or wood putty, or does a so-called “dowel repair” work better? I don’t want it to break again after a few months and am looking for proven methods that work well with typical KALLAX materials (particleboard). Thanks in advance for your advice!
chenValeri7 Nov 2022 10:57I would drill out the old holes, insert wooden dowels, and then screw the hinges back in. This usually provides enough stability. If the wood is completely crumbly, it's better to use a new piece of particle board or a repair kit.
Hello Tasau, the issue with torn-out hinges on the KALLAX shelf is unfortunately quite common because the particleboard on the door sides is not very sturdy. I recommend a somewhat elaborate but durable repair process: First, you should carefully fill the old screw holes with wood filler (preferably furniture repair filler) and let it fully cure – this takes at least several hours up to overnight.
Then, lightly sand the area to make the surface even again. After that, you can drill new screw holes – using thin drill bits and screws with short threads helps to avoid damaging the particleboard again.
Alternatively, if you want to be really sure, you can glue wooden dowels into the old holes, which you can either custom-fit from suitable hardwood dowel material or purchase at a hardware store. If the shelf’s door thickness and material strength allow it, this effort is worthwhile because it is truly stable.
Another point: use screws with a larger shaft diameter, but not too long, to prevent splitting the material.
I’m also wondering if the doors already have paint damage or if you have doors with a coating? That sometimes affects the choice of adhesive or filler.
How large are the torn-out areas exactly? Are they just several small shrink holes, or have parts of the particleboard completely broken off?
Hey Tasau!
I know how that feels, KALLAX hinge problems can be really annoying 🙂
Here’s what I did: used wooden dowels, as chenValeri suggested, then applied plenty of glue, and immediately put in new screws. If possible, use the original Ikea hinges—they fit perfectly and are an affordable replacement.
I totally agree – otherwise, you’ll just make the hole even bigger 🙂
Sometimes it helps to screw in a small metal plate as reinforcement if you don’t want to drill into the wood panel.
Enough talk – just give it a try, and it should work like new afterward! Good luck! ;-)
lorena schrieb:
One more thing: use screws with a larger shank diameter, but not too long
chenValeri7 Nov 2022 16:29Elodie schrieb:
Sometimes it helps to screw in a small metal plate as reinforcement Exactly, or so-called hinge plates. These help distribute the load over a wider area and prevent repeated tearing.
Elodie schrieb:
Sometimes it helps to screw in a small metal plate as reinforcementThat is actually a good idea that is often overlooked: metal reinforcements behind the hinges distribute the load much more effectively. Sometimes I also stick self-adhesive felt pads or thin wooden panels to the inside of the shelf unit to reduce vibrations and improve stability.
If you could provide me with the exact dimensions of your hinges and the door, I could also suggest suitable screw lengths and diameters for you, and whether special wall plugs should be used.
One more thing: do you use the doors frequently, and how heavy is the load on them? This affects the durability requirements of the repair.
