Hello everyone, some time ago I bought a Kallax shelving unit from Ikea and used the stylish doors that go with it. Now, some of the doors are damaged and I am considering replacing them. My question is: Are there original replacement doors for Kallax from Ikea, or do you have to look for alternatives? If so, what experiences have you had with replacement products or custom-made solutions? I need doors that are as durable and precisely fitting as possible, and easy to install. Thanks in advance for your tips!
About Palenar:
The durability mainly depends on the surface treatment. Melamine is durable, relatively moisture resistant, and easy to clean, which is why Ikea chose it for Kallax doors.
Alternative: Painted MDF doors have a very smooth surface and are more resistant to scratches; however, they are more complex to manufacture and significantly increase the cost.
For private users, I recommend melamine because it is affordable and low-maintenance.
Regarding hinges: Many use clip-on hinges from Hettich or Blum as replacements – they are durable and comparable to Ikea quality, provided the drill holes fit or are adjusted accordingly.
pinpa schrieb:
I had a local carpenter make doors from MDF with a white coating, and I ordered the hinges separately from Ikea (leftover stock on eBay).That sounds really good and matches exactly what I had in mind, thanks for the inspiration!
usbla schrieb:
For a precise fit, it’s recommended to create an accurate dimension drawing including all mounting points.I will measure the doors carefully again today and try to document the dimensions as exactly as possible.
Could you possibly share a reliable source for these “leftover Ikea hinges,” or any tips on how to identify the typical Ikea hinges?
Thanks again to everyone, you’ve been a great help!
