Hello everyone, I found the drawer handles on my Ikea Malm sideboard somewhat unsatisfactory and am considering replacing them with different handles. My question is: How difficult or time-consuming is it to remove the existing handles on Ikea Malm drawers and replace them with new ones?
I know that Malm dressers usually come with pre-drilled holes for handles, but how is the fit with other handles? Do you need special tools or experience? Or is a regular screwdriver enough?
Is there anything important to keep in mind—perhaps regarding the attachment or stability?
I look forward to your opinions and experiences, and any tips on suitable replacement handles. Thanks!
Replacing the handles on the Malm is generally straightforward. You usually only need a Phillips screwdriver.
The holes are standardized, but not all replacement handles fit perfectly. It’s best to measure beforehand.
If the new handles are too large or too small, you may need to drill new holes.
I understand how important something like this is for the appearance! I felt the same way.
The installation was easy for me, but I was still unsure if I was using the right screws and if everything would be stable. After the first handle replacement, I felt more confident.
Don’t worry if it doesn’t go smoothly the first time—that’s totally normal. 🙂
Technical facts: The IKEA Malm dresser uses Phillips-head screws, usually 16 to 25 millimeters (0.6 to 1 inch) long, depending on the handle.
The fastening is done from the inside, with standardized drill holes typically spaced 128 millimeters (5 inches) apart, known as the European standard.
If the handle dimensions differ, the front panel must be modified, which is challenging because the wood can easily splinter.
Tool restrictions: For a simple replacement, a screwdriver or a cordless drill with torque control is sufficient to protect the material.
Hi everyone, here is a brief guide on how to change handles on Malm furniture:
1. Loosen all screws on the inside using a Phillips screwdriver.
2. Carefully remove the old handle to avoid damaging the paint edges.
3. Measure the new handle: check the screw spacing, often 128 mm (5 inches), but please verify.
4. If the new handles have different dimensions, mark the positions and drill holes using a small drill. CAUTION: Pre-drill with a thin drill bit to prevent splitting.
5. Screw on the new handle; do not overtighten the screws.
Common mistake: tightening too much, which can crack the material or deform the front.
onMarcos schrieb:
Typical mistake: tightening too much, which can tear the material or deform the front panel.Exactly, that’s an important point. Tighten carefully with a gentle touch, and it will fit properly.
