ᐅ Replacing Billy Regal Shelves: Which Replacement Parts Are Compatible?
Created on: 29 Nov 2024 14:37
Jenamo
Jenamo
29 Nov 2024 14:37
I have an Ikea Billy shelf unit with the classic birch-pattern shelves, which unfortunately are quite worn in some places. Since I want to keep using the shelf, I’m planning to replace the shelves instead of replacing the entire unit.
My specific question is: Which replacement parts or shelves fit exactly into the Billy unit? Are standard shelves with the typical dimensions sufficient, or are there special models from Ikea or third-party manufacturers that you can recommend? I am especially interested in whether the shelf pin holes are the same in the usual options, so that I don’t have to drill new holes and can maintain stability.
Perhaps someone also has experience with alternatives in different materials or finishes that are compatible without compromising the shelf’s integrity? I would appreciate your tips, advice, or detailed information, preferably with references to dimensions, material thicknesses, and shelf pin hole spacing.
Thanks in advance!
Dilen
29 Nov 2024 15:48
Hello Jenamo,
Excellent question. When it comes to Billy shelves, replacing the shelves is not always straightforward if you want to maintain the original fit. The standard shelves from IKEA for Billy are usually 40 cm deep (16 inches) and 80 cm wide (31.5 inches) — these are the typical dimensions for most models. The thickness is about 1.8 cm (0.7 inches).
An important detail is the drilling holes for the shelf supports, which on Billy units are typically spaced every 3.2 cm (32 mm or 1.26 inches). If you use replacement shelves from another brand or a third party, make sure the hole spacing matches exactly, otherwise the position of the pins will be off, which can either cause extra work or reduce the load-bearing capacity.
Many third-party sellers on Amazon or other platforms offer so-called "Billy replacement shelves" designed specifically for these dimensions. Usually, the listing indicates which model the shelves fit (e.g., Billy 80x28 or Billy 80x40). Also pay attention to whether the surface is painted solid or laminated, as this affects appearance and durability.
If you decide to make shelves yourself from wood, it is worth working with a drilling template before starting to avoid mistakes. Also, note that the wood or particleboard used by IKEA is often coated with melamine, which is often missing on replacements made by others—this can be noticeable both visually and when cleaning.
In summary: it is best to buy official IKEA replacement shelves or pay very close attention to the measurements and hole spacing if you go with a third-party option. Which route are you taking exactly — just buying new shelves or cutting and drilling them yourself? Can you measure the existing shelf’s dimensions precisely again?
sanjon
29 Nov 2024 16:03
You can find replacement parts for Billy bookshelf shelves directly in Ikea’s online store. They always fit because they use the original dimensions. Third-party suppliers can be risky due to different hole spacing.
Kinbu
30 Nov 2024 09:12
Hi Jenamo,
I had the same problem with my Billy shelf some time ago. The shelves were worn out, and I didn’t want to throw away the entire unit. I bought replacements directly from Ikea back then, which is really the safest option. The shelves have the same dimensions: 40 x 80 cm (16 x 32 inches) in my case.
If you don’t necessarily need original parts, you can also look for shelves made of HDF or MDF boards that are offered at hardware stores. As Dilen already mentioned, it’s important to check the drill hole spacing. It’s a good idea to use a template from the old shelf to mark the support points and drill holes.
If you want to remove the furniture yourself, the shelf supports usually remain mounted on the wall, and the shelves rest on them.
It also helps to carefully measure the thickness to ensure the material is strong enough. For Billy shelves, as mentioned, they are often thin particleboard, which is relatively fragile, so avoid choosing material that is too thin.
Regarding your interest in alternatives made from other materials: glass shelves are compatible but usually require different fittings and tend to be more expensive.
I hope these tips help you! 🙂
koduga
1 Dec 2024 11:57
Dilen schrieb:
Also, make sure to check whether the surface is opaque or laminated, as this affects both the appearance and durability.
That’s true – I also think it’s important to consider how much wear and tear the new shelves need to withstand. This matters especially if the shelf is used by children or in high-traffic areas, since the surface type makes a big difference.
Personally, I was unhappy with self-cut particle boards at first. Even with the right dimensions, they always felt a bit unstable, and the edges weren’t finished well.
Maybe you can weigh up the potential disappointment or effort involved with some replacement shelves before you start.
If appearance is important, there are great options with adhesive foil coverings that you can apply yourself – turning a simple particle board into a really nice shelf.
Is your shelf fixed to the wall or is it used as a room divider? Sometimes that also makes a difference in terms of stability.
