ᐅ Replaced Malm drawer handles – any tips for improving durability?
Created on: 11 Jan 2017 08:37
ELVEDIN
ELVEDIN
11 Jan 2017 08:37
I recently replaced the drawer handles on my Malm chest of drawers because the original ones felt a bit stiff and didn’t seem very durable. Now my problem is that the new handles start to loosen after a relatively short time or even show marks on the material, which affects the appearance and could reduce their longevity in the long run.
My question to the community: What tips and experiences do you have for mounting handles on Malm drawers to ensure they stay secure and stable over time? Are there specific screws, adhesives, or perhaps preparatory steps that work better?
I would appreciate well-founded and practical advice, preferably with explanations of what has proven successful for you or where the typical weak points are. Thanks in advance!
GIBAPO
11 Jan 2017 12:25
Hello ELVEDIN,
to improve the durability of drawer handles on Malm dressers, I recommend the following steps:
1. Check and replace screws: The original screws are often quite short and do not fit optimally. Use longer stainless steel screws that grip the material better and create a more stable connection.
2. Secure threads: Applying a drop of threadlocker (e.g., medium strength type like Loctite 243) to the screw threads prevents loosening caused by vibrations during use.
3. Washers: When working with soft materials like particleboard, always use washers between the screw head and the handle to increase the pressure area and avoid damage to the wood.
4. Pre-drilling: Unlike simply screwing in, pre-drilling with a thinner drill bit is advisable to prevent the material from splitting.
5. For heavier handles or designer handles with irregular shapes, adding a small wooden plate or guide strip inside the drawer can provide additional stability.
This combination has proven effective in numerous projects and should significantly extend the lifespan. It is important to choose high-quality screws and threadlockers.
If you have any questions about the individual steps, I am happy to help.
chen67
11 Jan 2017 18:43
Hey ELVEDIN,
I also changed the handles on my Malm dresser and realized that simply screwing them on is often not enough, otherwise they eventually start to wobble annoyingly.
GIBAPO schrieb:
A drop of threadlocker on the screw threads prevents loosening due to vibrations during use.
I can definitely confirm the threadlocker tip! I always keep a small bottle of Loctite handy—this makes it quick and easy, and the handles stay firmly in place.
Also, if you want a bit more security, I stick a small piece of felt or foam rubber under the handle on the inside. This not only prevents scratches on the drawer but also cushions the pull on the handle. This way, the screws don’t press directly on the wood, which helps it last longer. 🙂
And yes, you should definitely use washers—better more than less. They protect the wood well and help prevent wobbling. Good luck with it!
Laure57
12 Jan 2017 09:13
Hello ELVEDIN,
I can only agree with the advice already given, especially regarding pre-drilling and the use of washers, which are essential. To go into a bit more detail:
Malm drawer boxes are made from relatively soft particleboard, which can be damaged over time by directly tightening screws. Therefore, pre-drilling with a drill bit slightly smaller in diameter than the screw shank is crucial. This reduces stress and prevents cracks or splintering in the wood.
GIBAPO schrieb:
When working with soft materials like particleboard, always use washers between the screw head and the handle to increase the contact area and prevent damage to the wood.
The washers distribute the pressure, ensuring the screw does not press into the material, which would otherwise compromise stability over time.
Furthermore, I recommend not tightening the screws too much — tightening just up to the point of resistance is sufficient. Excessive torque can damage the material around the threads.
Regularly checking and retightening the screws can also help maintain durability, especially if the dresser is used frequently.
If the new handles are metal, also check that the screws have the appropriate strength rating (e.g., 4.8 or 8.8) to avoid early fatigue.
I hope these tips help you attach the handles more securely and durably.
reoWilhelm
12 Jan 2017 20:07
Hi ELVEDIN,
chen67 schrieb:
Also, if you want a bit more security, I’d stick a small piece of felt or foam rubber on the inside at the bottom of the handle.
Absolutely great tip! I did something similar – the foam rubber acts like a shock absorber and reduces wobbling. Very useful.
Also, from my experience: if you buy drill bits or screws yourself, make sure to choose high-quality materials. It really makes a difference, especially with cheap hardware store stuff where screws quickly become dull or ceiling screws pull out.
With a bit of patience and the right tools, you can significantly increase durability and keep frustration low.
Good luck with the handle upgrade! 🙂
