Some time ago, I bought a piece of furniture from IKEA, specifically a Malm sideboard with a wood veneer finish. Unfortunately, some superficial scratches have appeared, likely due to everyday use and rearranging. I would like to repair these scratches myself or at least make them less visible without further damaging the paint or surface.
I am particularly interested in practical methods that work with relatively common household materials. Are there proven ways to remove or at least conceal scratches on Malm furniture? For example, using oil, wax, special repair kits, touch-up paint, or other tricks? What has worked well for you, and what definitely should be avoided?
I look forward to specific tips and experiences, including advice on proper preparation and aftercare of the furniture surface.
Thank you in advance!
Hello limima,
I completely understand how frustrating annoying scratches on furniture can be—I had the same issue with my Malm desk. What worked quite well for me was a combination of several small home remedies. First, I gently rubbed the scratches with a walnut shell. That might sound strange, but the natural oils in the walnut actually refreshed the surface a bit and visually masked minor scratches.
So you can definitely count that as one, without having to buy special products. 🙂 The important thing was to buff the surface afterward with a soft cloth. I’m not sure if this works on deeper scratches, though, as mine were too stubborn. For those, I recently ordered a repair kit and will be testing it soon.
Good luck—feel free to share what you try!
limima schrieb:
I'm especially interested in practical methods that also work with common household items.
Good evening,
For repairing scratches on Malm furniture, it is first important to determine the type of surface. Malm furniture is usually covered with a laminate or veneer, which means that repainting, as done with solid wood, is not possible if the protective layer is scratched. Below are some precise tips on methods that have been objectively proven effective:
1. Use a color-matched furniture touch-up pen or lacquer marker to precisely fill in minor scratches.
2. For superficial fine scratches, wax pastes are suitable to mask the defects; they are easy to apply and can be polished afterward.
3. Oil treatments have little effect on veneered Malm furniture because the oil does not properly penetrate the material but only remains on the surface.
4. For deeper damage, it is advisable to contact the manufacturer or IKEA directly for a suitable replacement part or repair kit, as DIY methods are often insufficient.
Always clean the surface thoroughly before application and avoid sanding with coarse materials, as the thin laminate can be easily damaged.
This caution is justified and should be strictly observed.
limima schrieb:
ohne dass der Lack oder die Oberfläche weiter beschädigt wird
Hi limima,
I’d like to go into a bit more detail in my response, as I’ve spent quite some time researching this topic myself. Malm furniture with foil coating can be tricky because the coating is only a few hundredths of a millimeter thick, and scratches often go down to the base material. Here’s a process I recommend:
1. Cleaning: Clean the surface with a mild detergent to ensure no dust particles interfere with the repair.
2. Assessment: How deep are the scratches? Fine micro-scratches can often be reduced with light polishing or polishing wax.
3. Small scratches: Wax sticks or repair wax (matched to the furniture color) can be carefully worked into the scratches with a spatula. Wipe off any excess immediately.
4. Deeper scratches: This is more complex. I have used fillers that you apply with a small spatula and then smooth out lightly after drying with very fine wet sandpaper (e.g., grit 1000 to 2000). Afterwards, touch up the area with a colored lacquer or marker pen.
5. Sealing: After repair, it’s very helpful to seal the entire panel again with fine furniture wax or a specialized wax applicator. This balances the surface structure and helps reduce future damage.
I’ve found it’s important to have a small set of different repair products, as not all scratches are the same. It’s not a perfect solution, but the furniture looks noticeably better afterward.
How deep are the scratches on your piece? That would be helpful to give more targeted advice.
Gregory schrieb:– exactly!
Always clean the surface before application and avoid sanding with coarse materials
Hello limima and everyone else,
I would like to add a more practical recommendation regarding the durability and maintenance of the repaired Malm furniture. Since the surface is very sensitive, repair attempts should not only be judged by appearance but also by how well the results protect against further use.
Even though wax sticks and fillers can effectively conceal minor scratches, they are neither waterproof nor scratch-resistant. Therefore, please consider the following points:
- After repairs, avoid wiping the furniture with excessive moisture to preserve the concealment.
- Avoid silicone-based furniture polishes, as they can damage the surface and cause uneven gloss.
- For larger or very noticeable damage, custom replacement parts or professional repair services may be a more sustainable solution in the long run.
In conclusion: These methods mainly serve cosmetic purposes and improve the look but do not address the fundamental issue of the sensitive foil surface on Malm furniture.
Surela schrieb:I agree, as different products are needed depending on the depth of the scratches.
I have found it important to have a small set of various repair materials on hand
