Good morning everyone,
I have a fairly urgent question: my IKEA Malm chest of drawers has swollen significantly on the bottom due to water damage. It’s the 3-drawer version, and the water seems to have been absorbed over several hours because a pot accidentally spilled. The particleboard structure appears to be softening, and some corners look swollen.
Has anyone dealt with something like this and knows the best way to repair such a chest without completely replacing it? Are there effective methods to harden the wood panels again or at least stabilize the surface? I’m particularly interested in tips on products, tools, and procedures—everything from sanding to sealing.
Thanks in advance for your help!
Hey Kau34,
you’ll manage it! 🙂 I once completely disassembled a Malm dresser after water damage, carefully worked on the panels, and was able to replace several parts. Unfortunately, IKEA doesn’t offer many replacement parts for particleboard, but sometimes you can find exactly these panels or repair-ready modules from used furniture part sellers online.
My tip: remove all screws completely, then gently take apart all components. Keep the edges clean and sand damaged areas before fitting new panels.
A fine jigsaw is great for this, and you should carefully score the veneer layer with a sharp utility knife to prevent fraying!
It’s fun, so don’t worry! 🙂 Don’t get discouraged!
That's brilliant, temeli! 🙂
I can only confirm that patience is key when restoring a dresser like the Malm after water damage! Minor damages can be effectively repaired with wood filler and good sandpaper.
It’s also great that wood hardener and clear varnish can make the dresser look almost new again – as long as you take your time!
Do you perhaps have any tips on which brands or products are especially good for wood hardener?
Khalil schrieb:
Do you perhaps have any tips on which brands or products are especially good for wood consolidants?Good question! I personally often use products like "Consolan wood consolidant" or "Clou wood consolidant plus" – both penetrate effectively and harden the material. It’s important to choose a consolidant suitable for coated or veneered particleboard to avoid damaging the veneer and finish.
When applying, it’s best to apply several thin layers and allow each layer to dry thoroughly in between.
Also, before application, I recommend ensuring the dresser is completely dry and clean, and removing any loose parts.
Does anyone know if the swelling fully reverses, or does it rather lead to stabilization?
danial60 schrieb:
Does anyone know if swelling fully reverses or if it usually just stabilizes?Swelling is generally largely reversible through drying; however, the material may lose some volume in the process.
The structure of the particleboard is damaged by water, so although the consolidant strengthens the fibers, a perfect return to the original condition cannot be guaranteed.
This means the panel can be usable and stable again but may appear slightly warped or uneven.
From a technical perspective, a complete repair without replacing the affected panels is often only possible if the damage is minor.
