Hello everyone, I have a Billy shelf unit where some of the connectors used for stabilization have partially come loose. Specifically, these are the connectors that secure the back panel and the shelves. My question is: which repair methods have you found to be truly effective for permanently reattaching these connectors? I am interested in both simple DIY solutions and professional repair approaches. Are there any special adhesives, reinforcements, or alternative fastening options you would recommend? Thanks in advance for your tips!
A precise and durable repair of the BILLY connectors ideally requires a combination of several measures.
1. Remove old, damaged holes and repair them with suitable wooden dowels.
2. Use a strong adhesive PU glue, as it resists moisture better than conventional PVA glue (e.g., Ponal).
3. Provide additional reinforcement with small metal brackets, mounted invisibly on the inside.
4. Prepare the drill holes using an appropriate drill bit to avoid further weakening the material.
This is correct; especially if dismantling is considered later, threaded inserts are advantageous.
As a side tip: The back panel of the BILLY shelf contributes to stability, so it is worthwhile to secure it with additional fasteners after the repair.
maureo schrieb:
Threaded inserts enable a stable, yet removable connection.
