Hello forum community
I am Micha and I need some good advice.
I am currently renovating our bathroom.
Now I have made a very silly mistake.
I didn’t apply the top coat plaster far enough down.
Now I’m missing a strip next to the tiles.
I have already tried to plaster the missing strip afterward.
Of course, the result is poor.
At the joint, there is a strip without texture from the first layer of plaster.
Does anyone have a useful tip for me?
Regards, Micha
Regards, Micha
Bau-Micha16 Dec 2016 23:18The solution to the problem depends on how I finish the plaster.
You could redo everything, add another row of tiles, or even wallpaper over it.
Isn't "Rotband" a type of gypsum-based smoothing plaster?
Our fine plaster has a very fine texture after troweling.
alter002916 Dec 2016 23:43Rotband is a bonding plaster, as Peanuts already mentioned. It serves as the base layer for the textured plaster. I would do it exactly as he described: apply the base coat again and then put the textured plaster on top. Unless you have a bathroom with 50 sqm (540 sq ft), this should be a manageable effort. The alternative would be to constantly be frustrated about how it looks or to hope you get used to it.
Bau-Micha17 Dec 2016 00:02I probably have no other option... everything needs to be redone.
Our plasters here are a bit different.
The base coat is a lime-cement plaster applied with a machine.
Then a very thin lime fine plaster is applied on top.
