ᐅ Repair of chipped concrete on interior wall of a prefabricated panel building (Plattenbau)
Created on: 10 May 2021 11:46
Tolentino
Hello dear forum members,
I helped a friend install various things in her newly occupied prefabricated apartment.
Beforehand, I read up about the special characteristics of the notorious walls in Berlin prefabricated buildings. Still, on one wall, the concrete along with the wallpaper chipped off on the other side of the drilled hole. I assume I pressed too hard and perhaps the concrete was already weakened here. Now, of course, we need to repair this.
The chipped area is about 20 cm (8 inches) high, 10 cm (4 inches) wide, and 2 cm (0.8 inches) deep. The entire interior wall has a thickness of 6.5 cm (2.6 inches). I assume it is a concrete wall without plaster. The woodchip wallpaper is glued directly onto it and then painted. At the moment, the cracked woodchip wallpaper still holds the concrete fragments, but it is clear that more will fall off.
My planned approach:
1. Make large cuts in the woodchip wallpaper and remove it
2. Remove loose fragments and dust
3. a) Treat the damaged area with a primer (necessary? How absorbent is the concrete, which has already been pasted once?)
3. b) Let dry (are there faster options here?)
4. a) Smoothly fill the damaged area with filler (Is ready-mixed filler still okay here, or is the area too large and especially too deep? Or should I even use cement? Do I have to work in several layers?)
4. b) Let dry (are there faster options here? I’m inexperienced and don’t feel confident using fast-setting cement with a 3-minute setting time; I will definitely need longer to achieve a smooth finish)
5. a) + b) Apply primer again and let dry (necessary?)
5. c) Apply paste and woodchip wallpaper (should the wallpaper fit precisely or overlap the remaining edges?)
5. d) Let dry
6. Paint (Does anyone know if there is a standard white commonly used by housing associations? Is it traffic white?)
Is my approach okay, or are there any major mistakes?
Is there perhaps a simpler method?
Since there are so many drying times, this will be a job spread over several days with multiple visits. Is there a way to speed this up or skip some steps?
Many thanks and best regards
Tolentino
5. d) Let dry
Tolentino
