ᐅ Should KALLAX be repaired immediately after water exposure?
Created on: 13 Apr 2022 09:34
talea
talea
13 Apr 2022 09:34
I have a question regarding my KALLAX shelf from IKEA: If the shelf gets wet, should you start repairing or at least drying it immediately, or is it also possible to wait and monitor whether the damage stabilizes or diminishes on its own?
I ask because I read that the boards are made of compressed wood-based material, which can swell or warp after exposure to water. On the other hand, the shelf is relatively sturdy, so I wonder if urgent action is really necessary or if longer-term monitoring is sufficient.
What are your experiences? Do you have any tips on the best way to proceed if the shelf gets wet? And how quickly should you react to prevent further damage or permanent warping?
I look forward to your assessments and possible recommendations for repair or care after water exposure.
Thanks in advance!
BEMAU
13 Apr 2022 13:22
Hello talea,
In general, it is indeed advisable to take action immediately after water contact with KALLAX shelves. The panels, as you mentioned, are made of pressed wood-based material (particleboard with a melamine coating). These materials tend to swell and permanently deform when exposed to moisture.
Quick drying prevents water from penetrating deeply into the fibers and causing irreversible damage. I recommend first removing any excess water as quickly as possible and placing the shelf in a well-ventilated, dry area.
If swelling is already visible, simple repairs are often not possible – usually, only replacing the affected parts or, if feasible, sanding and sealing the surface helps. It is important not to wait too long, as the deformation tends to become permanent over time.
In short: Immediate repair or at least prompt drying and monitoring is the most reliable way to prevent major damage.
V
vin_leo
13 Apr 2022 15:47
BEMAU schrieb:
Quick drying prevents water from penetrating deep into the fibers and causing irreversible damage.
I agree, especially since you wouldn’t want a KALLAX in the living room exposed to rain, right? 😅
I also recommend removing all the shelves after they get wet, then brushing them off or drying them—plus allowing some airflow. Using a fan or something similar often speeds up the process.
Once, I didn’t dry one corner of my shelf right away—it later swollen quite a bit and looked unpleasant. Since then, I’ve been a bit more particular and act immediately.
In short: it’s better to tackle it right away, or you’ll regret it longer later on 😉
Davebla
14 Apr 2022 08:59
Interesting thread.
I think the question should also be considered from the perspective of cost-efficiency: KALLAX shelves are relatively inexpensive and of course affordable, but repairing such compressed wood-based materials can be quite tricky.
talea schrieb:
How quickly should you react to prevent further damage or lasting warping?
The answer is often within a few hours at most, depending on how much water has penetrated. Deep saturation with standing moisture quickly leads to swelling and permanent damage. If only the surface was slightly damp, immediate drying is sufficient.
vin_leo schrieb:
I once didn’t dry a corner of my shelf right away – it later swelled a lot
That’s a good example, as some damage only becomes visible after a few days. It is also often underestimated that the floor (on which the shelf stands) can absorb moisture. Protecting the substrate is therefore important too.
In the end, everyone has to weigh whether the effort of repairing is worthwhile or if it’s better to replace the shelf if the damage is too severe.
