ᐅ Repairing holes in a concrete floor – debris and sand underneath
Created on: 1 Nov 2016 22:23
koolkoe
Hello, we have just purchased an old building and now have many questions. For example: we have a concrete floor with a large hole in it. Below the hole, there is a cavity about 5-10cm (2-4 inches) deep, followed by debris and sand. I would like to fill this hole with mortar, but does that work on a sandy base? Can I simply apply mortar generously once it has dried through, or will I face the same issues again in spring as we do with our roads?
I look forward to your answers...
Best regards, Thomas
Hi,
yes, it is outdoors. I can’t say for sure if it is concrete; it’s a typical flooring. Unfortunately, I’m not familiar with the wide variety of materials available. So I would prefer to approach the problem in a “lawn mower” way for now. Maybe in a few years everything in that corner will be replaced anyway. Until then, it should be watertight because I don’t know if there is just soil underneath. Right next to it is our house, and that should stay dry.
Best regards, Thomas.
Bieber08154 Nov 2016 08:48So there is nothing underneath? No basement or similar? Just soil ...? Assuming yes, that is the case: This concrete slab (functioning like a paved surface) does not contribute to the building’s waterproofing. The house itself must be properly sealed. Any repairs are only cosmetic.
Explain the application to the building materials supplier you trust and buy a bag of screed cement (or similar). Chisel out the crack until the edges are solid and no longer crumbly. Then either sweep thoroughly or vacuum. Slightly dampen the area, then fill the crack and smooth it out. Make sure to compact well (tapping, tamping). Let it dry, and you’re done.
...thank you, thank you. Yes, the bricks are on the agenda. However, it is very full. Thanks to your advice, I will probably just leave it as a quick fix and simply fill it in with cement mortar. Clean it thoroughly beforehand and apply some bonding primer, and maybe sometime later do something entirely different that looks better...
Regards
Regards
