ᐅ Renovation Tips for a Very Small Bathroom with a Shower Instead of a Bathtub
Created on: 16 Dec 2018 10:01
Z
ZwuselSepp
Hello forum,
I want to renovate my bathroom (have it done), but it’s incredibly difficult. So far, the companies haven’t presented any good proposals. The window is also problematic, but I am allowed to replace it with a double casement window (approved). One side could be fixed, which would no longer be a major issue.
Maybe someone here in the forum has a brilliant idea? The bathroom needs to include a shower, toilet, and washbasin. The drain for the toilet is at the back right next to the window.
Zwusel
Zwusel
hemali200321 Dec 2018 00:12Fummelbrett schrieb:
One very bold idea: a shower in the entrance area. That means a walk-in (curbless) shower, with the main door opening outward as usual, and then installing a shower door inside the frame. Then putting another shower door at the narrow section, which would always remain open. It’s actually quite crazy, but this way you’d have a large shower, space near the toilet, the sink, and the washing machine. The window wouldn’t be an issue either.
It’s definitely a pretty unique setup *laughs* I had thought that at first too—that it’s probably the only option that really adds comfort. If you wipe the floor after showering, I don’t think it’s that impractical. But it is certainly quite unusual...
hemali2003 schrieb:
I could imagine a walk-in shower with a depth of 70-80 cm (28-31 inches) and the full room width along the top side of the plan. Access from the left (so a glass partition 90 cm (35 inches) wide starts on the right wall and ends 70 cm (28 inches) before the left wall). The window is located inside the shower – I’ve seen this quite often. Because of the tiled floor and since it will be squeegeed after showering anyway, the window is easily reachable. Maybe it could also be moved, for example, all the way to the left corner.
To the right of the shower is the toilet, and in the front left corner is the washbasin.I still like hemali’s idea – it matched my thinking too. Then the washing machine was added 😉. There are shallow washing machine models, about 46 to max. 50 cm (18-20 inches) deep and nearly 85 cm (33 inches) high.
Therefore, the bathroom door should open outwards – I find that very important overall. Then the washing machine goes on the left, with a shelf above it as marked in orange. Next to the washing machine, under the shelf, there is space for the drain and washing machine connections. On top of that, a countertop basin.
The toilet is on the right, with a built-in housing about 120 cm (47 inches) high, matching the shower’s partition depth – it also serves as storage for shower items inside the shower. The toilet is installed with enough clearance from the shower glass partition.
In front of the window, possibly curtains made of shower curtain material that can be drawn over the window while showering and then drip comfortably back into the shower.
On the left side, marked in red, there would be room for a towel radiator.
Key point: the passage between the washbasin and toilet will only be about 40 cm (16 inches) wide. However, that may still be acceptable.
Z
ZwuselSepp27 Dec 2018 11:20Thank you all for the suggestions. Currently, I am considering the option from @kbt09. I need to check whether it is possible to integrate the washing machine with the sink or place it next to it, and whether it is possible to position a sink in the center—so that it is half above the washing machine, and so on.
ZwuselSepp
ZwuselSepp
