I have 40 granite kerbstones from road construction that I would like to use for building.
Unfortunately, over the years, a very thin layer of tar from traffic has formed in some areas. How can I remove it?
The surface of the stone is very rough. Solvents and scrubbing don’t work for me.
Thanks in advance
Thanks in advance
tadeus3214 Jun 2025 16:01So sanding is out of the question. I can’t get into the rough texture with the sandpaper at all.
Solvents don’t seem to help either. Only a slight visible effect.
I tried using a wire brush attachment for the angle grinder. It doesn’t work. It does lighten the surface a bit, but it just drags the dark residue across the surrounding area.
I also tried using a flame from a Bunsen burner. The effect is that some spots chip off thinly and look like new in those areas, but for most of the surface, nothing happens. Too much gas consumption for too little result.
My next approach would be an electric or pneumatic chisel. I already ordered one for the Bosch hammer, but I suspect the cheap €20 chisels from Amazon won’t hold up on granite (even though they claim to be suitable). I’ll give it a try. Maybe there will be some effect, and then I can buy a better chisel. According to the specifications, even chisels from well-known brands like Bosch are too soft for granite. The datasheets say they are only intended for concrete and tiles.
Are there any proper chisels available from stonemasonry suppliers? Maybe someone here knows something.
nordanney4 Jun 2025 23:36tadeus321 schrieb:
I tried using the flame from the Bunsen burner.How about using a roofing torch? No pressure regulator and full power. It could burn everything away. But it might use up a few gas cylinders.
