ᐅ Remove the tile floor or install parquet/vinyl flooring over it?
Created on: 13 Sep 2021 00:22
HubiTrubi40
I raised this topic in another thread, but it seems more appropriate here. I wanted to get an idea of whether it’s feasible to install hardwood flooring over tiles (I wouldn’t do it myself, since I have no experience with this) or if the tiles need to be removed first. I have read that it is possible, but I’m wondering how the transition to the kitchen, which is tiled, or to the hallway works, and whether door trimming would need to be considered. Also, the tiles aren’t perfectly level—I haven’t measured, but there appear to be slight unevenness, and in the middle, the screed seems to have settled a bit (see photo).
What should I expect to pay per square meter (if the tile floor can stay)? I wouldn’t choose expensive hardwood; I’ve seen some nice options around 50 euros/m² (about 4.65 USD/ft²).
Also, upstairs we plan to replace the carpet with hardwood or vinyl flooring (I lean toward hardwood since it can be sanded). The carpet can be removed quite easily, but only the pile; underneath remains a layer (either adhesive or foam). Can flooring be installed over that, or does it need to be completely sanded off?
Thanks in advance and best regards,
Hubi
Winniefred7 Jun 2023 20:50
I would follow the tile installer’s advice and put the tiles and parquet over the existing floor. Anything else is unnecessary waste of money and time. It also creates a lot of pressure and produces construction debris that has to be disposed of. Regarding underfloor heating, having tiles over tiles would, of course, be more efficient. But it should work fine this way as well. The heat just has to pass through an additional layer, and with parquet (wood, which insulates) some heat will be lost. You need to be aware of that. Otherwise, from my point of view, there is no reason not to install the new floor directly on top. The tile installer will have checked the old tiles. If they are firmly fixed, they make a good base for another layer.
The only consideration on my part: if the underfloor heating will need to be replaced anyway (due to age or efficiency), it might be worth considering starting from scratch and rebuilding everything.
