Hello everyone, I own a Billy shelving unit from IKEA that has developed some signs of wear over the years. Especially along the edges and on some of the shelves, there are small scratches and discolorations that are difficult to remove. My specific question is: What effective methods or home remedies exist to gently and precisely remove these typical signs of wear on a Billy shelf? The materials should not be damaged, as it is not solid wood but rather a veneered surface. If anyone has tips on suitable care products, repair kits, or techniques, I would appreciate a detailed response. Thank you in advance!
The BILLY shelf is made of particleboard with a melamine coating. Therefore, common household treatments like wood oil or sanding are not recommended, as they can damage the surface. For scratches and superficial wear, I recommend using special repair markers or wax sticks, which are available at furniture stores. These products are matched to the color of IKEA furniture and can make the marks nearly invisible. It is important to clean the surface thoroughly beforehand and apply the products sparingly.
Blavin schrieb:
The BILLY shelf is made of particleboard with a melamine coating.Thank you for this important information about the material type. That also explains why sanding is not an option. I wonder how accurately the wax sticks match the color, as my shelf is the white model. Are there generally differences in repair kits that are specifically designed for white surfaces? Are there any experiences with long-lasting results on BILLY shelves? I am concerned that some products might peel off or discolor after a short time.
monari schrieb:
Are there generally differences in repair kits that are specifically suitable for white surfaces? Yes, repair kits are often categorized by color tones, and for light surfaces, there are white or ivory wax sticks or fillers available. It is advisable to use products from manufacturers specializing in furniture restoration, such as brands like Effekt or Holzmichl. These products mostly contain pigments that accurately match the color. Proper application is important: clean the surface with a mild cleaner, apply the product with a spatula, remove excess material after a short drying time, then polish the result. This way, the sealing lasts for several years.
I think people worry way too much about signs of wear. Especially with an inexpensive shelf like the BILLY, professionally repairing and covering up damage often ends up being a waste of time and money. It’s usually better to just buy a new one, right? Of course, I understand wanting to preserve furniture, but with constant repairs there’s always the risk it will eventually look fake.
That’s exactly the point – melamine doesn’t forgive much. You either accept the signs of use or replace the piece. A little bit of patina doesn’t hurt. 🙂
monari schrieb:
The materials shouldn’t be damaged because it’s not solid wood but rather a veneered surface.
