ᐅ Is it possible to apply a Q2 finish to drywall?
Created on: 25 Jul 2017 18:09
Henrik0817123
We will soon have our house finished on the inside with drywall panels, which will be skim-coated and sanded to a Q2 finish. I understand that Q2 can vary in appearance and that factors like perception, lighting, and so on play a role, but can general statements be made on this topic regarding:
- Ceilings: I have increasingly read that it is common to paint them directly (usually two coats), as there tend to be fewer issues with grazing light, seams, etc.
- Walls: We would also like to paint them directly. We are not very particular about the walls but definitely want to avoid wallpapering (if we do, it would be smooth non-woven wallpaper to be painted afterward). What is the best approach here? Are there specific paints or “better” substrates for this? What can end up looking bad in the end? Is it mainly the edges where you can see where one drywall panel ends or begins?
Does anyone have tips? There is also roll-on or trowel-on textured paint, but from my research, that didn’t seem very appealing so far…
Regards
Winniefred23 Aug 2017 21:24
That matches my experience as well. I would generally avoid painting directly onto the surface. It’s better to apply textured plaster or wallpaper first. If we had painted directly, any unevenness would have been visible.
Arifas23 Aug 2017 22:14
So, applying a primer and then a textured roller finish should be possible with Q2 and not very high requirements?
Arifas23 Aug 2017 22:27
Nordlys schrieb:
Yes
Thank you [emoji1]
winnetou78
23 Aug 2017 22:33
I have looked at a few houses from different companies.
And I have to say, it depends on the plasterer. I saw some Q2 that looked like Q3 to me. But I also saw Q2 that was far below that.
Many of those with good plaster told me they just label it as Q2 because of claims, but generally, the quality is better.
23 Aug 2017 23:57
What is this about?
Has this thread been hijacked?
It is still about painting drywall... for questions from Q2 or ü, please create a new thread or use the existing ones (there are plenty).
Nordlys
24 Aug 2017 09:03
No. Still on topic, Yvonne. For Q2, you paint the drywall. That’s what it means. Whether it’s drywall or wall plaster doesn’t really matter: Q2 is not ready to be painted, only ready for wallpaper. Q2 is still too uneven and plain wall paint is too thin to cover that. Possibly use textured paint. Karsten
