ᐅ Refrigerator, sliding door front / dimensions of IKEA built-in refrigerator
Created on: 7 Aug 2014 16:38
schnecki
schnecki
7 Aug 2014 16:38
I’m sure someone here can help me. I’m currently trying to figure out if I can install a built-in refrigerator with a niche size of 122 cm (48 inches) using a sliding door system behind two connected 60 cm (24 inches) cabinet fronts, or if the hinges of the front panels need to be positioned above and below the refrigerator door itself. (The refrigerator door is about 118 cm (46.5 inches) high.)
Thanks and best regards from schnecki
IKEA-Experte
7 Aug 2014 19:09
Hello, 120 cm (47 inches) for the door is quite tight. How exactly do you plan to position the refrigerator and then properly cover everything above and below it?
schnecki
8 Aug 2014 08:02
Hello Ikea expert,
Below there is a drawer with a 40cm (16 inches) front height. So if necessary, I can lower the base for the refrigerator by one grid level and then possibly place something under the refrigerator to achieve the correct height. Above, I was thinking of a regular door, but if needed, a lift-up hinge could be used there as well to cover the refrigerator unit.
IKEA-Experte
11 Aug 2014 13:49
Give it a try and report back. Keep the panels wrapped until the last moment so you can exchange them if it becomes clear beforehand that they won’t work.
