ᐅ Recommendations for Garden Pumps to Empty a Sump Pit
Created on: 28 Jul 2020 15:17
Scrooge McDuck
Hello dear forum community,
Are there any recommendations for garden pumps to empty a shaft about 4 meters (13 feet) deep and approximately 1 meter (3 feet) wide? The emptying needs to be done regularly.
I am not familiar with garden equipment at all.
The pump should not be placed floating in the shaft but rather stand on a solid surface, with one hose reaching into the shaft to draw water and another hose to discharge it. At least, that’s how I imagine it.
I prefer not to buy twice and am willing to spend a bit more for a product with a long service life.
Many thanks in advance!
Nida35a28 Jul 2020 20:37
My wife loves using the rainwater from the cistern for her plants.
Vicky Pedia28 Jul 2020 20:46
I have a low-cost pressure booster system from a budget supplier installed on the cistern. It has been working for 8 years!!! (You could also buy a new one). Sure, the noise is outside. But for a true gardener, the sound of the pump is like music for 1 to 2 hours!!!
Scrooge McDuck
28 Jul 2020 21:08
The water is quite clear and seems to come from some kind of underground spring. This also made the earthworks quite expensive.
The groundworker redirected the water into the newly created pit and regularly pumped it out during the work. The pit has been full since yesterday, and now the water is rising to the surface in another location.
We want to use the water both for watering the garden and the indoor plants.
pagoni2020
28 Jul 2020 21:17
What happens if you don’t pump it out? Will it overflow or do you have a spillover?
Scrooge McDuck
28 Jul 2020 21:25
There is an overflow present. As a layperson, I feel that water at a level about 10cm (4 inches) below the overflow in the shaft no longer has enough force to push into the shaft, causing it to appear at a low point next to the shaft.
pagoni2020
28 Jul 2020 21:30
Wow, do you maybe have a picture of it? I can't quite imagine it right now. So if you want to take water from it like from a tap whenever needed, then a domestic water system would be the way to go. You can find those quite cheaply online.
