ᐅ Recommendation for Interior Doors in Rooms with Very High Ceilings
Created on: 18 Jun 2020 11:33
Seven1984
Seven1984
18 Jun 2020 11:33
on the side where we have our interior doors, the ceiling height is almost 5 meters (about 16 feet) due to a staggered shed roof, not a suspended ceiling. The ring beam is at a height of 3 meters (about 10 feet). This is also the height of the lowest side.
What height and width would you suggest for the room doors? What should we consider?
Thanks, regards
Vicky Pedia20 Jun 2020 18:52
I would choose 985 x 2110. This is a standard size and suits the rooms well.
hampshire
20 Jun 2020 18:56
Take a look here: Which interior door height for which ceiling height, general discussion thread #44
21 Jun 2020 00:20
Vicky Pedia schrieb:
I would choose 985 x 2110. That is a standard size and suits the rooms.
That is NOT a standard size...
Seven1984 schrieb:
where our interior doors have a very high ceiling of almost 5 meters (16 feet) (staggered
.. and your or any standard size does not fit here either. How can you recommend a door width without even knowing the floor plan and room usage?
Such statements are unprofessional!
Vicky Pedia21 Jun 2020 08:03
That is NOT a standard dimension ...
Oh, then DIN 18101 must be incorrect. I can only learn here!
And if you read carefully, it was about ceiling heights, not usage. But you are right. I probably don’t know much about this.
Seven1984
27 Jun 2020 18:10
Oh, then the DIN 18101 standard must be incorrect. I can only learn from this!
And if you read carefully, it was about ceiling heights and not usage. But you are right. I probably don’t know that well.
We have decided in favor of it, thank you
