ᐅ Recommendation for Digital Heating Thermostat
Created on: 27 Dec 2020 21:29
_
_Ugeen_
In our future house, an air-to-water heat pump from Daikin (Altherma 3 R ECH2O 308/508 H/C (H) (Biv) 8kW) will be installed. We now want to replace the analog heating thermostats with digital ones. Since there are countless options available, I wanted to ask here if you could recommend any. They don’t need to be smart home compatible.
Nida35a30 Dec 2020 16:33
We did not look into heating system design or heating load calculations beforehand, just like 95% of all homeowners. The air-to-water heat pump works. The annual electricity consumption for the heat pump and domestic hot water is about 3000 kWh, and household electricity use for lighting, refrigerators, sauna, cooking, etc. is also around 3000 kWh. Since we maintain different room temperatures by turning off certain rooms and leaving windows slightly open—for example, the bedroom is currently at 16°C (61°F)—we might be able to save some energy. However, sleeping with closed windows is not an option for us.
Happy New Year, Nida
motorradsilke
30 Dec 2020 16:46
Nida35a schrieb:
We didn’t really look into heating system design or heat load calculations beforehand, just like 95% of other homeowners don’t. The air-to-water heat pump is working.
The annual electricity consumption for the heat pump and hot water is about 3000 kWh, and household electricity for lighting, refrigerators, sauna, cooking, etc., is also around 3000 kWh.
Since we keep different room temperatures by turning off rooms and tilting windows—for example, the bedroom is currently at 16°C (61°F)—we might save a bit, but sleeping with closed windows isn’t for us.
Thanks. Do you have a separate meter for the heat pump electricity?
A different question: how long did your construction process take with Mein Haus?
Nida35a30 Dec 2020 16:53
1. yes
2. much faster than 7 months is not possible, for us due to EL and time, 10 months
motorradsilke
30 Dec 2020 17:15
Nida35a schrieb:
1. yes
2. it can’t be done faster than 7 months; in our case, due to energy certification and scheduling, it took 10 months
We were promised 6 to 7 months, possibly even 5 months (this still needs to be clarified). For the energy certification, we only have painter and flooring work left, which we can also complete after partial move-in.
Nida35a30 Dec 2020 18:04
However, we are in someone else’s thread here, so let’s not upset the original poster. Please create a separate thread for your questions.
motorradsilke
30 Dec 2020 18:06
Yes, I know, but the original question was answered in detail. Unfortunately, I can’t message you directly, as private messages are only available after a large number of posts.
