ᐅ Source cement with the finest grain size
Created on: 1 Apr 2021 21:59
Nightfil
Nightfil
1 Apr 2021 21:59
for the renovation of thin joints 2-3 mm (0.08-0.12 inches) wide, I am looking for a cement with a maximum grain size of 1 mm (0.04 inches) that also swells or does not shrink during setting.
Does anyone have any suggestions?
The only thing I have found so far is a swelling or packing mortar with a 2 mm (0.08 inches) grain size.
A swelling grout mortar is not an option. The material should not flow away but remain in the joint.
Thank you
danixf
1 Apr 2021 22:11
Can’t you just use grout that is also used for tiles? It has a fine grain and is available for both indoor and outdoor use.
Nightfil
1 Apr 2021 22:28
This concerns a bed joint in the brick masonry that needs to be repaired. I don’t think joint mortar is the right material for this, is it?
