ᐅ Proportion of interior doors for rooms with a ceiling height of 263 cm?
Created on: 16 Dec 2018 09:30
Christian NW
Christian NW
16 Dec 2018 09:30
Create a separate thread for this topic, as it doesn’t seem to exist specifically yet. This is about proportions and whether the appearance still fits...
Looking for opinions from professionals with relevant experience. Who can share their insights from experience?
Does this look good?
223.5mm (8.8 inches) thick doors in rooms with a height of 263cm (8 feet 7.4 inches) – or are the doors visually too large for the room?
wrobel16 Dec 2018 10:47
Hello Christian
We have a house with a single-pitch roof. The ceiling heights range from about 2.40 m (7 ft 10 in) to 3.40 m (11 ft 2 in). In the hallway area where the room doors are located, the height is between 2.40 m (7 ft 10 in) and 3.00 m (9 ft 10 in). Heights between 2.40 m (7 ft 10 in) and 3.00 m (9 ft 10 in) are acceptable. The height in between is perfect.
Olli
Christian NW
16 Dec 2018 11:46
wrobel schrieb:
Hello Christian,
We have a house with a mono-pitched roof. The ceiling heights range from about 2.40 m (7 ft 10 in) to 3.40 m (11 ft 2 in). In the hallway area where the room doors are located, the height varies between 2.40 m (7 ft 10 in) and 3.00 m (9 ft 10 in). The heights at 2.40 m (7 ft 10 in) and 3.00 m (9 ft 10 in) are acceptable. The range in between feels perfect.
Olli
Thanks for the feedback, so in your opinion it should look good...
Does anyone else have experience with this? :-)
Bookstar
16 Dec 2018 13:06
How tall are you that you need doors like these? If you are under 2 meters (6 ft 7 in) tall, I would definitely go for 211 cm (83 inches).
Christian NW
16 Dec 2018 19:42
We are quite average in height ...
it’s all about the appearance!
The living room is 44 m² (473 sq ft), the kitchen 14 m² (151 sq ft), the hallway 14 m² (151 sq ft) ... the house is 180 m² (1,938 sq ft).
Hence the question about ... Does it look like that ...
Bookstar
16 Dec 2018 21:34
Why? Then there is no reason. It’s a small house with standard rooms, etc. Why have unnecessarily tall doors? What’s motivating you to do that?
