ᐅ Are radiator valves controllable via an app or similar methods?
Created on: 30 Oct 2015 16:12
U
Umbau-SusiWe have the following problem:
In all rooms, we have radiators with programmable thermostatic valves directly on the radiator. This works well so far.
Now, the problem:
Three radiators are over one meter (about 3 feet) high, and the thermostats are located near the floor at the base of the radiator. This means you can only reach them by lying down on the floor in front of them.
We have set up a cozy lounging area in front of one of these radiators. Because of this, we would like to be able to quickly adjust the radiator temperature manually, but...
Does anyone know if there are radiator valves that can be controlled via Wi-Fi without requiring any permanently installed additional parts?
Any hints would be appreciated.
Sylvia
Now, the problem:
Sylvia
No, Olli, from the sofa down to a reclining position in front of the valve, still can’t see what temperature it’s set to -> attempt. Then getting up again. And later doing the whole thing in reverse. Fixed heating times are programmed anyway.
The smartphone version is better if it exists.
Sylvia
Sylvia
Computersylvia schrieb:
No Olli, get off the sofa into a reclining position in front of the valve, still can't see what temperature is being set -> try. Then get up again. And later reverse the whole process. Fixed heating times are programmed anyway.
The smartphone option is better
if it exists.
SylviaGood morning
No, of course you’re not supposed to crawl under the sofa.
Valve at the bottom – thermostat and timer on top.
Available from the recognized manufacturers Da... and Hei... in their product range.
Olli
