ᐅ Question about the oven cabinet
Created on: 18 Jul 2012 17:15
Izzie_7604
Izzie_7604
18 Jul 2012 17:15
I am currently planning my new kitchen, based on the Faktum series. For my built-in oven, I would like the matching base cabinet (item number: 298.438.92), and I have a question specifically regarding this cabinet. How far back does the oven extend inside this base cabinet? Unfortunately, there is a pipe on the wall, so I need to cut a small recess approximately 3cm (1 inch) high and 3cm (1 inch) deep into the side panels to allow the cabinet to fit flush against the wall. Will this work, or does the oven protrude too far back?
Thanks in advance for your help!
EinrichtungsNiete
19 Jul 2012 00:38
You are probably the best person to answer that question yourself. 😉
Do you already have the stove? Which one is it or will it be?
If yes, measure the installation depth.
If not, try searching online for a datasheet with the installation dimensions.
Then you can clearly see whether the stove would collide with the flue pipe...
