PavorNocturnus15 Nov 2025 21:02Years ago, we stayed in a holiday home in Croatia. The interior walls were painted white but had a very fine textured plaster. Not smooth, but more like sandpaper. If you rubbed your arm against it, you could actually abrade the surface a little.
I suspect it was a type of textured plaster known as slip-coat plaster. However, the slip-coat plaster I am familiar with is much coarser. This was really a fine, yet abrasive surface. Homogeneous and quite evenly speckled—not irregular like wallpaper with woodchip or textured vinyl.
Can anyone tell me what this type of finish is called and how it can be achieved?
PavorNocturnus15 Nov 2025 21:42It’s probably not textured paint. The surface is not uniform enough. The desired finish is much cleaner and resembles coarse sand more closely.
PavorNocturnus16 Nov 2025 10:54A surface like 600-grit sandpaper describes it quite well
wiltshire16 Nov 2025 10:59You can achieve this texture using various materials and methods – including additives and felts, as well as by controlling the particle size.
