ᐅ Tension cord in Venetian blind has snapped. Is this covered under warranty by the builder/developer?
Created on: 4 Aug 2018 10:06
italiano83
italiano83
4 Aug 2018 10:06
We still have one year of warranty left before the 5-year period expires.
Now, a drawstring of the blinds has broken, and they move up and down unevenly.
Our builder refuses to cover this under warranty because it is considered a movable part.
The repair, including disassembly, is estimated to cost around 600 euros.
Now my questions to you: Wouldn’t something like this be covered under the builder’s warranty?
We had a turnkey contract.
Thanks in advance.
Bookstar
6 Aug 2018 18:20
Yes, I think it’s excluded in this case; it’s a wear part, similar to brakes on a car. You can’t replace it either.
HilfeHilfe
6 Aug 2018 19:42
600 euros for a draft part seems like a rumor to me. But wear and tear is inevitable.
Payday
6 Aug 2018 21:09
By a movable part, something else is meant ^^ Movable refers to parts that are not permanently attached to the house, not that they can be physically moved or pulled, for example. A shutter is clearly a fixed part of the building since you do not take it with you when you move out. Whether a pull cord is a wear part is doubtful at first. If it were a wear part, it would have to be designed so that replacement is easy and inexpensive.
PS: This is also one of the reasons why shutters are usually operated electrically rather than opened and closed by hand.
Caspar2020
7 Aug 2018 08:54
italiano83 schrieb:
Now a pull cord of the blind has broken, and it moves unevenly up/down.
italiano83 schrieb:
Repair including disassembly etc. is supposed to cost around 600 euros.
What kind of blind are we talking about here? It must be quite large, right? Or is it a venetian blind / external louver (also called a "Raffstore")?
Payday schrieb:
I doubt that though. If it were a wear part, it would have to be designed so that replacement can be done easily and cheaply.
Tell that to the automotive industry. Think of car lamps in some models.
Payday schrieb:
ps: that’s also one of the reasons why blinds are not opened/closed manually but are usually installed with electric motors
Most people I know have electric roller shutters or sometimes venetian blinds. For electric blinds, it’s quite rare.
Payday
7 Aug 2018 18:08
Caspar2020 schrieb:
Tell that to the car industry. Keyword: car lamps in some models.
For several years now, it has been mandated by directive that bulbs can be replaced without much hassle. This does not apply to Xenon and LED lights...
You are right about the shutter. I was considering the part integrated permanently into the house, not the "pleated blind" hanging at the window priced at 600€. As mentioned countless times, a picture is worth a thousand words. If the component is not a permanent part of the building, it is not covered by the 5-year warranty anyway. A "pleated blind" or something similar is not fixed in place, as it can simply be taken along. Nobody takes along a roller shutter or venetian blind...
