ᐅ Should cork flooring be protected in advance against office chair casters?
Created on: 8 Jan 2013 16:05
O
OrschelHello,
We had cork parquet installed in the upper floor and in the home office. Cork is naturally a softer surface. Now I would like to know if it makes sense to put something under the office chair, or if the cork will be damaged over time from the constant rolling back and forth?
Yes, it will ... we also have click cork flooring in our office. It is quite durable, but with constant heavy use, you will likely see wear over time. Buy one of those plastic mats at Ikea for 25 €; we've been using one for years, and it also helped protect our softwood parquet flooring.
gissilala19 Jan 2013 17:13Yes, that’s true, the plastic mats are great. We even installed them under our sideboard and dresser, just to protect the floor in the long run.
steinkopf13 May 2013 12:53With this mat, you can’t go wrong, but it is aesthetically unattractive. As an alternative, you can also use connected bamboo rugs.
