ᐅ How to Properly Adjust an Air-to-Water Heat Pump with Underfloor Heating
Created on: 15 Dec 2019 16:52
M4rvin
I have been searching around and reading the manual for my Elco air-to-water heat pump, but I haven’t fully figured it out yet...
I have a manifold on the ground floor and first floor; the recommendation is to fully open everything, set all thermostats to maximum, and then adjust the heating curve on the heat pump low enough to roughly achieve the desired temperature.
Is that more or less correct?
At the moment, every thermostat (except bathroom/bedroom) is set to 20°C (68°F), and the temperature in each room is about 20.9°C (70°F) (bathroom slightly warmer, bedroom slightly cooler).
However, I’m surprised by the high electricity consumption — it has been 800 kWh in just 2 months.
135 m² (1455 sq ft) living area
Elco Split 7 kW
Circulation pump not yet connected
Thanks in advance
M4rvin
Mycraft15 Dec 2019 20:03
It’s up to you. Either request the calculation or take out pen, paper, and a calculator.
WingVII
15 Dec 2019 20:03
However, it probably isn’t worth changing everything drastically right away. Electricity consumption tends to decrease a bit during the second or third winter. I would suggest monitoring the situation for a few more months.
tomtom7915 Dec 2019 20:20
Since this question has come up so often in the last few days, maybe someone could take the time to write down the steps for the hydraulic balancing. This way, even beginners can understand it.
Tobibi
15 Dec 2019 21:20
Very good idea. I would be very interested in that. Probably many people are currently dealing with it because it really seems like winter is finally coming.
Daniel-Sp
15 Dec 2019 21:46
Mycraft schrieb:
The valves on the heating circuit distributor (HKV) should be roughly set according to the calculation (the better the calculation, the less work required). The actuators should either be completely switched off or left powered off in the open position.
Then you can fine-tune the flow rate at the valves.
M4rvin schrieb:
I don’t think anything was actually calculated here. So far, nothing has been adjusted either.
It seems there is no calculation at all, or at least none was provided. Without documentation, it becomes difficult. How else could he obtain important data such as pipe length, supply line length, pipe spacing, pipe diameter, and HKV connection details if the screed is already installed? He cannot calculate the required flow for the heating circuit by himself! The only option left is to measure return temperature and room temperature with the thermostatic radiator valves (TRVs) fully open (or with actuators removed). If room temperatures are consistent everywhere and the return temperatures are approximately equal, the hydraulic balancing is correct and he can proceed with the thermal balancing.
However, the total volume flow must be sufficient for the heat pump! Unfortunately, this is often not taken into account during hydraulic calculations, even by professionals. They usually rely on assumptions and do not even calculate the room-specific heating demand at the homeowner’s desired room temperature, nor do they consider the heat pump’s rated flow volume.
Likewise, homeowners often reduce the volume flow for the heat pump by frequently adjusting the TRVs, causing inefficient short cycling.
Some tips can be found in a parallel thread:
"Underfloor heating, it gets so warm in the house when the sun shines"
ludwig88sta
17 Dec 2019 10:46
tomtom79 schrieb:
Since this question has come up so often in the past few days, maybe someone could take the time to write down the steps for the hydraulic balancing. That way even beginners can understand it.
That’s true. The thread "https://www.hausbau-forum.de/threads/bodenheizung-luft-wasser-Wärmepumpe-haus-zu-warm-wenn-sonne-scheint.33030/" probably deals with the same topic.
If one or two heating experts could team up to write a pinned tutorial that is also easy to understand for beginners – that would be AMAZING
