ᐅ Proper Insulation for Copper Pipes
Created on: 2 Feb 2021 11:59
Jonas90
Jonas90
2 Feb 2021 11:59
I have a problem with the copper pipes at my water connection not being insulated, which causes condensation to form on the pipes.
How can I insulate these parts?
Standard pipe insulation sleeves don’t seem suitable because it’s made up of small components.
I hope you can help me.
Water pipe with green shut-off valve, pressure regulator, and pressure gauge on copper pipes.
Rusty water pipes with green shut-off valve and blue safety cap.
T_im_Norden
2 Feb 2021 14:23
Try searching for Vela Clip
V
vaderle
2 Feb 2021 14:23
I have applied self-adhesive insulation tape (PE tape) at the points.
Stefan2.84
5 Feb 2021 07:01
Do the pipes need to be insulated? I noticed the same issue at our place last weekend. Now it’s better again. Why does it appear sometimes and not at other times?
T_im_Norden
5 Feb 2021 07:25
Humidity in the utility room and the outdoor water temperature.
It is not necessary, but if you want to avoid condensation, it can be done.
Stefan2.84
5 Feb 2021 07:32
Ok, thanks. I’ll just do it myself then. All the other pipes are insulated. So this one could have been done as well.....
