ᐅ Proper Cleaning of IKEA METOD Wood Cabinet Fronts Using Common Household Methods
Created on: 20 Nov 2017 08:13
Pitaflo
Pitaflo
20 Nov 2017 08:13
Hello everyone, I have a question about the proper cleaning of IKEA METOD wooden fronts using household products. My fronts are painted white, and I want to keep them clean without using harsh chemical cleaners, as I don’t want to damage the wood or the paint layer. Does anyone have experience with effectively and gently removing dust, grease, or light dirt using everyday items like vinegar, baking soda, or dish soap? I am especially interested in recommended mixing ratios, how to prepare the cloth, and important things to watch out for to avoid damaging the surface.
lisbi
20 Nov 2017 08:49
Hello Pitaflo, when cleaning painted wooden surfaces like those on METOD, caution is necessary. I recommend: - Mix lukewarm water with a small amount of mild dish soap (just a few drops), not too much to avoid residue. - Use a soft, lint-free cotton cloth, wrung out well so it is damp but not wet. - Gently wipe the surfaces without scrubbing. - Then wipe again with a dry cloth to prevent water spots. I would avoid using vinegar or baking soda directly, as acidic or alkaline substances can damage the protective coating.
Cecilera66
20 Nov 2017 09:07
I would generally avoid using vinegar on painted surfaces. Cotton cloths and dish soap are ideal. Afterwards, wipe dry.
Ixvin
20 Nov 2017 09:22
Hello Pitaflo, I completely understand why you are looking for a gentle cleaning method. METOD fronts are particularly sensitive to harsh cleaning agents. A tip: if you have grease stains, mix warm water with a small amount of dish soap. Then use a soft sponge or cloth and wipe in circular motions. Important: do not use too much water, as this could cause the edges to swell. Some people also use a very mild soap, such as pure soap, dissolved in water. This is also very gentle. After cleaning, always wipe down with a dry microfiber cloth. This protects the surface and helps maintain the paint finish.
Tufu57
20 Nov 2017 09:56
Be careful with vinegar! A little dishwater is enough. Wipe damp, not wet!
Pitaflo
21 Nov 2017 06:57
Thank you for the tips so far. I have an additional question: How should stubborn stains be cleaned, such as dried coffee or grease that has partially soaked in? Is a mild soap solution still enough, or is there a home remedy that offers more cleaning power without damaging the wood surface? I would prefer to avoid using sandpaper or chemical cleaners. At the same time, I’m interested in whether occasional (careful) polishing of the surfaces with specific oils or wax treatments is worthwhile to make them more resistant to dirt.
