ᐅ Proper Ventilation in the Stairwell of a Multi-Family Building? Electric Window on the Upper Floor
Created on: 14 Feb 2017 09:53
rudiherbert
rudiherbert
14 Feb 2017 09:53
Hello.
I hope this is the right forum for my question.
How should the stairwell in a new multi-family building be properly ventilated?
In the attic (from ground floor, upper floor) there is a window that opens electrically.
It can only be opened with a special key.
When it is closed (which is almost always the case), the air in the stairwell is stagnant.
To avoid mold and improve the air quality in the stairwell, the upper window would need to be opened to create airflow between the entrance door and the upper floor.
However, this window (a fire protection window) is not easy to open.
Question:
If the upper fire protection window is opened to create airflow, would this violate any regulation?
Or why is such a window equipped with an electric opener?
Could there be issues with the fire protection insurance if the window is kept open?
The airflow would ventilate the stairwell well.
Thank you very much!
14 Feb 2017 12:56
Do you have a property management company?
Iktinos
14 Feb 2017 13:31
rudiherbert schrieb:
Assuming you open the upper fire protection window to create a draft, would that violate any regulation?
No, why would it?
Bieber0815
14 Feb 2017 17:31
But this window (fire protection window) is not that easy to open.
In case of fire, this window should (or must, depending on the local building code/planning permission) open automatically. This allows smoke and heat to escape and hopefully keeps the stairwell as an emergency exit usable. There are minimum requirements for the clear opening area of the window.
Ventilation is separate from this function; it just should not allow rain to come in.
rudiherbert
14 Feb 2017 18:28
Bieber0815 schrieb:
In case of fire, this window should (or must? according to the local building code?) open automatically. This allows smoke and heat to escape, making the escape route via the stairwell (hopefully) usable. There are minimum requirements for the clear opening size of the window.
Ventilation is independent of this; it should just prevent rain from coming in.
Great! Thank you very much! That helped me a lot!
