ᐅ Concrete staircase – handrail?
Created on: 1 Jul 2014 20:15
milkie
milkie
1 Jul 2014 20:15
so many decisions to make.
We will have two concrete staircases (ground floor to first floor to attic). The lower flight is straight, the upper flight has a 1/4 turn.
I like brick or masonry half-walls, but my partner prefers stainless steel railings. Of course, price is also a factor. Does anyone know roughly the price difference between these two options? Or does anyone have a "mix" of both? For example, masonry at the bottom and railings at the top or something similar?
I find it difficult to find information online because most houses only have one staircase or narrower staircases.
Good luck
milkie
Manu1976
1 Jul 2014 21:22
We have also recently dealt with this question. We solved it by having the handrail of our concrete staircase from the ground floor to the upper floor built masonry-style. The balustrade on the upper floor will be done the same way. However, due to structural requirements, we cannot install another concrete staircase to the attic (only a wooden ceiling), so we will install a better space-saving staircase there instead. This will be made of beech wood and without risers, as will the railing. I think it will look quite good.
WildThing2 Jul 2014 07:43
Hello Milkie,
I think it’s definitely possible to mix them. Although I also like a continuous masonry parapet. I’ve seen several houses where the wall went from the basement all the way up to the attic and was only about half-height in the attic. (Otherwise, a railing was usually mounted on the wall.)
Many also have a door to the basement, so the stairwell would be separated anyway.
We will probably go with a concrete staircase all the way from the bottom to the top. However, I prefer a wooden or stainless steel railing. Partly because of the light coming through, and if the railing is only half-height on each floor, it’s easier to carry things up to the upper floor than if the wall is fully continuous masonry on the ground floor.
