ᐅ Issues with Unintended Drafts
Created on: 13 Feb 2022 01:05
Porselll
Hi,
I’ve moved into a newly built apartment (student dorm), so it’s basically a single room with a small attached bathroom. Unfortunately, my room is located right above the entrance, where a lot of smoking happens frequently. Now I have the problem that when the windows are closed, a strong smell of cigarette smoke comes into my room. Since everything is relatively new, I assumed that the window seals are still effective, and I suspected these “trickle ventilator” slots above the windows. I have two of them directly above the windows, each with a small dial that’s supposed to let me limit the airflow. I turned both dials to the closed position, but the smell is still there, and sometimes I feel a slight draft, although I’m not sure if I’m just imagining that.
My question is whether you think it’s okay if I just tape over the slots to see if the smell goes away. Would that pose a significant mold risk? I’m really getting desperate and would appreciate any advice!
Tolentino15 Feb 2022 15:06
Maybe just put up some no-smoking stickers on the walls there? If you manage to achieve even 50% compliance, it might already help you a bit.
Alternatively, place an ashtray within sight but somewhere else, where the smoke doesn’t drift toward you.
Fummelbrett!
15 Feb 2022 20:20
I like Tolentino’s idea with the ashtray – I might even take it a step further: if space allows, I would quietly set up the cheapest or donated (classified ads, notice boards) terrace chairs/benches/tables in a spot within sight where the smoke no longer drifts toward you. It could even become a nice little corner if there’s enough room.
Porselll
16 Feb 2022 00:01
Unfortunately, all of this is directly disposed of and corrected by the building manager. He is very nice himself but faces a lot of pressure from the student services organization, as they carry out regular inspections... it’s all not that simple, unfortunately 😀
KingJulien16 Feb 2022 02:27
You could try using an activated carbon fleece in or in front of the slots to see if it helps. Just a spontaneous DIY idea.
